305 bogs when warmed up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2014, 09:33 AM
Hello last spring i bought a VERY clean box chevy caprice..had a few miner things to attend to under the hood nothing that seamed major...b4 i go any further please be advised that when answering my questions please put them in terms so that a child could understand because I only know very basic car stuff..
also might help if I mention what im working on here.... 1989 Chevy Caprice Classic 305 tbI
Vin letter E 94k miles
the interior and exterior have all been restored and look new.. the engine is all stock other than dual exhausts coming of the exhaust manifolds... starts up and runs like a champ for it be in stock it runs good for in town use but once I take it on a ride somewhere out of town it almost seems as it warms up it starts to bog down . bogging down as in I almost have to push the gas pedal to the floor to engage the passing gear to get it to take back off... I put my car in the shop and they ran multiple diagnosis I knew I had a oil burning problem transmission leak.. brake fluid leak and coolant leak.. they said that the head gasket test passed fine. did not leak oil and that the oil burning was from my valve seals in which they gave me an oil change an added ProSeal to oilmy oil to help with oil consumption.. replace the brake lines to fix brake fluid leak.. flushed and replaced transmission fluid tranny filter and gasket which took care of tranny leak... so after $1012 at the shop, my car still bogs down from what it seems 20 current ones its well warmed up.... after re contacting the shop and telling them about it they said its probably because I have 24 inch Chrome heavy wheels on it and it takes a lot to spin them...well the proublem with that is it did this b4 i stuck 24s on....so what do i do now to fix this proublem other then pull it and throw a race car engine in it LOL (Joking) please il take what advise i can get if u need more info il gladly tell it
Old 04-30-2014, 10:23 AM
T-bucket23's Avatar
Wiki Edits: 26
Is the check engine light on.
Do you know if it ever goes into closed loop.
There are a lot of things that can cause your issue. if you can find someone with an OBD1 scanner they can look at what the O2, MAF, map etc are doing. My guess is you may have a bad sensor and one it warms up, goes into closed loop, the fuel metering is not correct
Chet
Old 04-30-2014, 11:11 AM
Nope never seen my check engine light come on before other than when i start it...and i have no idea what anything of the other stuff is at all lol sry...i dont have any 1 to test syuff for me other then shops
Old 04-30-2014, 11:31 AM
RWENUTS's Avatar
What does it do if you manually shift it?
Try it in 3rd gear if it's an overdrive tranny or try it in second if it's a 3 speed.
Old 04-30-2014, 11:52 AM
t bucket and rwenuts
okay T bucket I googled closed loop and that does seem plausible enuff to get checked out to either determine or rule out if that is a possibility.. And RWENUTS honestly I don't know because I've never tried to drop it into one of those gears but around 3pm est il b back to my drop yard rdy to go home i live 21miles away from my yard i pull out of and generally about 5 miles away from my destination: whether it be work to home or home to work id say ,95% of the time this boggong happns daily and il will try it and get back to u on what happens but when i do do this what exactly should I be looking 4 and should I not be looking for
Old 04-30-2014, 11:58 AM
RWENUTS's Avatar
You just want to see if it bogs in a different gear. Running in 3rd or 2nd revs your motor higher.
Old 04-30-2014, 12:07 PM
Ok il do it and get back with u on the results
Old 04-30-2014, 12:19 PM
Obd1 scanner is a code reader like the ones autozone and o reillys have correct i can swing in and see if ne thing pops up on my way home as well if thats the case
Old 04-30-2014, 01:13 PM
Got P R D with a circle around it D 2 1....ive always drove in D with vircle around it and im gonna drop it down to the D...Or should i b in D daily....and drop it down to 2?
Old 04-30-2014, 01:24 PM
The mobile view is crap
Do you have catalytic converters on this? If your driving around sixty m.p.h.drop it down to the d without the circle. The d without the circle is 3rd gear and the d with a circle is overdrive or 4th gear.
You could also be facing issues with the vehicle speed sensor.
Old 04-30-2014, 01:32 PM
Ok i say yes it still bogged down down shifting from circled D to D
Old 04-30-2014, 01:37 PM
Yes still has a catalytic converter on it crussell 85...auto zone said no on obd1 scanner...said take it to a shop...pfft
Old 04-30-2014, 03:41 PM
Investing in a decent scanner that will do live data is always a good tool to own. What kind of bogging are we talking about? Like it chugs and acts like it wants to stall? In your original post you said if you kick it into "passing gear"which is just the transmission shifting from overdrive to drive (3rd gear). If that's the case then moving the gear selector to d without the circle should do the same thing.
How long does the car have to cool down to go back to normal? Is the engine running warm? When the bogging occurs try shutting the car off after its safely parked and see if there's any issues restarting
Old 04-30-2014, 04:48 PM
Ok heres an example for u...get in car fires up np..ur driving thru a small town...few lights a few stop signs...merge on to a us highway speed limit is 55 u drive around 8miles going 55nonstop np yet u drive thru a small town on the high way that makes u slow down to 40 to pass thru the town maybe a mile then gos back to 55 so u apply pressure to pedel and instead of it gradually moving up to speed like a normal car it feels like ur towing another car and in order to break it of it u put the pedel to the floor...takes off like ur passing someone ...u finelly get to 55 and feels like car is just chugging along then it kinda passes n comes back till u reach were ur going...go inside for 20min get back in car to go back home and stars off fine like when u got in it before u left......no issues restarting...hell -20 degrees outside middle of winter hasent been started in a month...crank it over np like a champ..... I have had it die on me at a light like 2 times outta a hundread for no reason...i dont no if it runs warm or hot cause i only have a dummy light no temp gage and i have never seen it cum on for all i no it dosent even work thats y when i put it in the shop they said they put the sniffer on it and everthing reguarding the colling system was in good shape...case when it 1st started happing when i got it i thought was overheating and running like **** cauae thats what it feels like..chugs down lossess hp but i have had a car blow a head gasket and ran hot and it barly ran had no power but this comes and gos....like mayb starved tor air or bad sensors or starving from fuel or mayb even some cloging in the raidator or the thermastate isent opening and clossing properly i have no idea...hope this helps
Old 04-30-2014, 05:55 PM
Get a temp gauge on it. They're called dummy lights because your a dummy if you just rely on the light. If you go from 55 mph to 40 and then back to 55 the car is probably staying in overdrive. If you have to cram the pedal to the floor for it to downshift you may have a throttle valve cable issue, some people call them kick down cables. Google how to adjust it, then adjust it. How well does the transmission shift?
305, boggs, chevy, hot, warm
84 305 runs then bogs out. RYDERSC89 Engine 11 04-20-2014 02:16 PM
Breakin for warmed over engine? JMSTOY Engine 9 02-14-2012 04:15 PM
dead miss once warmed up 86Crewcab Engine 7 06-05-2011 06:37 AM
Q-jet bogs until fully warmed up Berliner Bel Air Engine 12 02-28-2006 06:47 PM
warmed over 350 nova33 Engine 4 11-01-2003 08:59 PM
