Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 build ?
Thread: 305 build ?
Old 12-31-2012, 07:55 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Well with the parts you have posted the cr will be 11.36:1
The 10cc dome on the piston is a mistake for building for pump gas.
If you mean to say it is a -10cc dished piston then the cr will be
a bit on the low side 8.95:1
A better match for the -10cc dished piston for that motor would be to combine with a 58 to 60cc head.
This get the cr to a 92 octane pump gas happy 9.8:1 to 10:1.
Is this what you are wanting to build.?
Camshaft selection: need more info on the car and how you will be using it.
