Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 build ?
Thread: 305 build ?
  #23 (permalink)
Old 01-05-2013, 05:35 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If you were to use a conventional head say a ported stock #4416 305 head with 1.94x 1.50 valves
on this engine, the 142 supercharger kit for this is less expensive. Its $2000.
If you were to do a good job porting the heads the power will be very similar to the vortecs.
Substitute the XE cam in the article for a Comp cs 268AH-14 cam 12-404-4.
Its roots blower friendly. Just right for this blown 305.
If you have a good used 305 with the 8.6:1 dished pistons and the 416 305 heads
you have a real good base for this build.
