Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 build help
Thread: 305 build help
Old 08-23-2010, 01:13 PM
my87Z's Avatar
my87Z my87Z is offline
like i mentioned the 2.02/1.6 valves will be too much/close to the 305 cylinder walls, you wont be able to go over 1.94/1.5 and that is what the vortecs have. the TF heads are pretty much out of the question, now a set of vortecs may work but you will spend 500.00 to get a set that have been rebuilt and worked the way you want then vs you can find a set of 4416 heads for 50-100.00 and have them rebuilt for 200ish and it wouldn't be too hard to make 300hp with them just dont expect to turn the 305 up much past 5000rpm
