We're right back to what heads (and thus what CR) are you going to use? What gear ratio and stall speed?
If it's stock heads (should be 58cc not 68cc), I would NOT run anything any 'beefier' than a Comp 262 in your C-truck. Forget about the idle sound, unless that's ALL you want and to drive a pig otherwise. |
ok, no idle isnt what i am aiming for, just would like a noticeable change. The heads are stock but have heavy springs on them and the pistons are flats, it was estimated that it would be close to a 10:1 cr.
If the xe262 is the way to go then ill do that, i was just ready about how the 270h was an older design and liked higher cr, thats why i was leaning towards that grind. Thanks for the input. |
stall is stock, well a v6 stock stall and gears are stock but sorry no idea what they are..ill have to jack the truck up to determine that.
If you take a look at that build link I posted, you'll see that the XE268H cam they used made best power at 6,100 rpm. |
flat top pistons are being put in, so around 9:5:1.
and thanks for the heads up on the rpm range, ill take a look at that. |
not trying to bash...but to get good power out of this motor is gonna need compression. Not saying its not possible, 305 Sprint cars out here get around 600+ hp from thier 305's...but they have some work done to them...A LOT of work...
I think ill try the xtreme 4x4 262 cam, it seems like the right direction for me, its definitely got the torque i need.
stroked a 305
I can't imagine duplicating the mileage again but I'd like to build one for myself. Practical having something that will work cheap... and run too. Most satisfying results of any small block I ever built. including 400 based stuff. |
| CMC '34 Coupe 1992 Build | ffas23 | Hotrodders' Lounge | 11 | 12-04-2008 12:32 AM |
| 305cid/372hp who said it couldnt be done | King Kong | Engine | 41 | 11-11-2008 03:41 PM |
| dirt track 305 | groomer | Engine | 12 | 04-20-2008 02:46 AM |
| 305 head on 350 | savman1 | Engine | 4 | 10-15-2006 09:18 PM |
| 305 Heads...Vortec or something else? | Ozz1967 | Engine | 0 | 04-13-2006 11:47 AM |
