![]() Jester |
The performer RPM is the best intake to bolt on a SBC.
If the engine has a low compression ratio its really hard to cam it. Does it have dished pistons? what is the cylinder head casting number? There are only a few that are worth even looking at . And they need serious work to wake up. with home porting,,,,4416 is best. 601 next best ... 450 434 junk....ditch these small valves small bad ports 2bbl vortec 305 059 (58cc) from a L-30 has some potential. vortec L31 062-906 great when shaved .050" on a 305. A hot rodded 305 needs compression ratio stiff gears and a high stall. more is better. Always start by assessing the basic health of what you got. Simple compression test. Last edited by F-BIRD'88; 02-01-2013 at 06:23 PM. |
Factory pistons. |
Which factory piston? flat top, dished, rebuilt. Ya it matters. |
does the kit come with cam/lifters/springs? you said 500.oo budget.. you don't need the rpm intake if your not going to rev it past 5400rpm much |
your torker isn't starting to help things till 3500-4000rpm buy then the heads are starting to get out of breath.. any dual plan will make a world of difference the j/y intakes only gonna work if your running a q-jet spread bore carb if you are gonna run a square bore carb, get a used aftermarket dual plane.. |
| What are some of the best CHEAP cars to build up? | RexKarr | Hotrodding Basics | 29 | 04-16-2010 10:07 AM |
| cheap 400hp build... | rezervation_pitbull | Engine | 21 | 10-04-2007 03:21 PM |
| Cheap HP on a sb 305 | 1980Impala | Engine | 7 | 05-09-2003 04:02 AM |
| cheap mods to a chevy 305 | camarokid05 | Engine | 8 | 12-14-2002 07:24 AM |
