305 build up on the cheap - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-02-2013, 11:09 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by vinniekq2 View Post
I wonder how much horse power you might get switching from torker to dual plane?
If I was doing an elcheapo I would use the torker and maybe a ported spacer(4 hole with bullet nose) a low lift solid lifter cam and take advantage of the gears.
This is one of those times you follow fb88 and his back yard hot rodding.
Vinnie: FB88:
We agree I posted that already 4 ported spacer and solid cam every one must have read right by it! That would be the cheap combo That would work very well with the right carb or mods on his present carb. and a good timing curve with a basic shift kit home installed !!
Jester
  #32 (permalink)
Old 02-02-2013, 09:10 PM
vinniekq2's Avatar
305 = high perforfance
Originally Posted by F-BIRD'88 View Post
I don't know how to build a 220hp engine.
If you want 220hp use the stock intake.
they are easy to build,find a 300 horse power 305 that has a super charger on it,and take the super charger off.
  #33 (permalink)
Old 02-02-2013, 09:15 PM
Banned
If you use the 305 HO heads with the damn Y exhaust crossover fill the damn thing with grout, plain old machine grout will work and you'll pick up power and economy.
  #34 (permalink)
Old 02-03-2013, 12:23 AM
Who is your post aimed at?
Actually a 305 that has 140, 150 hp stock jumping to 220 hp is a 70 hp gain on a small budget! That's a 45% gain!
That's something to brag about for a young builder and 500 dollars!
  #35 (permalink)
Old 02-03-2013, 12:31 AM
Who's your post aimed at?
  #36 (permalink)
Old 02-03-2013, 06:50 AM
Banned
I guess it would be the OP, building a 305 on a budget... I didn't really plan on addressing it to one particular individual.
  #37 (permalink)
Old 02-03-2013, 07:54 AM
Banned
none... peak.. but power under the curve.. low to mid-high in the rpm band will pick up tons..
  #38 (permalink)
Old 02-03-2013, 08:05 AM
Banned
it's a low buck 305...
220hp is about it.. without pulling it down and blueprinting the whole works..
larger valves and high lift cam, valve hits the cyl wall..
I got 306hp at the wheels in my 5spd '85 t/a but that was alot of work, require super 94 gas.. rowdy cam that not play nice with an automatic.
corvette alum heads and the cyl walls notched for valve clearance..
what a r.p.i.t.a it was to get the ccc to work with it. and pass the sniffer.
  #39 (permalink)
Old 02-03-2013, 11:11 PM
306 hp at the rear wheels with a 305 Supercharged? N.O.?
Jester
  #40 (permalink)
Old 02-03-2013, 11:28 PM
vinniekq2's Avatar
re manifolds?
You are talking about power under the curve,why?Its a build for cheap,and the only power to worry about is full power. When it comes to acceleration/gears/cheap all in one sentence,take the peak cheap power.
buying the dual plane would waste money,I agree with your post
i
  #41 (permalink)
Old 02-04-2013, 03:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't know why the 305 L30 Vortec heads haven't caught on? They flow real good unported- a **** load better than any other 305 head- and other than the need for a Vortec intake, SA rockers and centerbolt valve covers, it's a plug and play deal.
A mild cam and recurve the distributor, long tube 1-5/8" headers and dual exhaust, will have you all over 300 HP and good torque w/o needing to spin it to the moon.
This can be done for $500, the headers and exhaust system can be reused, there's never a problem reselling a Vortec intake. In fact, the entire 305 could be sold at a profit.
  #42 (permalink)
Old 02-04-2013, 08:41 AM
Banned
Jester
2 mopar 2.2 turbo's
The Following User Says Thank You to gearheadslife For This Useful Post:
ss396si (02-11-2013)
  #43 (permalink)
Old 02-04-2013, 12:15 PM
2 mopar 2.2 turbo's
That's a yes.
I thought so! That's around 400 hp at the fly wheel.
Jester
  #44 (permalink)
Old 02-11-2013, 11:13 AM
ss396si's Avatar
Good post and good way to hop up a 305 on a budget.
The "059" L-30 305 vortec heads get overshadowed by the L-31 350 heads for sure. but on this build and budget thye can work well.
They also can be improved by hand porting and shaving the decks for compression on a 305. Especially if it has a dished piston.
You'd want to get them down to around 51cc and use a shim gasket on a
dished pistoned 305.
Now it will have enough flow and compression to take and use a bit of a cam.
Keep the cam torquey. It is easy to get carried away with cam choice on a 305.
A Small CID engine is very sensitive to camshaft selection. The cam choice will make or break it.
Converter and gears are critical. Getting the compression ratio up is most critical.
If your 305 had dished pistons you need to pay attention to this.
This can work very well.
That sounds great, what car did those L30 heads come out of?
The cam ill leave in for now, I have the gears and stall plus everything else.
  #45 (permalink)
Old 02-11-2013, 12:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They are basically 1996-up truck heads. Also used on some SUVs. Unlike the L31 5.7L Vortec head, the L30 305 head doesn't seem to be available new from Scoggins-Dickey, etc. (GM parts dealers), although I might not have been looking in the right place.
A little info on them is here.
The following list is for L31 5.7L head donor vehicles. But some/all of the same vehicles may have been available w/the L30 305:
1996-2002 Chevrolet Express/GMC Savana full-size vans
1996-1999 Chevrolet/GMC C/K full-size trucks
1996-1999 Chevrolet Suburban/GMC Suburban full-size long wheelbase SUVs
1996-1999 Chevrolet Tahoe/GMC Yukon full-size short wheelbase SUVs
What are some of the best CHEAP cars to build up? RexKarr Hotrodding Basics 28 04-15-2010 09:05 PM
cheap 400hp build... rezervation_pitbull Engine 21 10-04-2007 04:21 PM
Cheap HP on a sb 305 1980Impala Engine 7 05-09-2003 05:02 AM
cheap mods to a chevy 305 camarokid05 Engine 8 12-14-2002 08:24 AM
