305 and carb Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2006, 11:23 PM
How can I find out what year my 305 is? It was transplanted in my 68 Chevy panel wagon in 81 from a Firebird.
And, how do I find out what carb is on it? Looks to be a Rochester, 2 barrel, has BC next to fuel inlet, but all I can find with BC is 1 barrel. Carb either needs rebuilt, or if there's a good cheap option, replaced. I'm not looking to smoke the tires, just a good reliable old truck.
Thanks,
trapperjack
Name:	panel wagon carb 003.jpg
ID:	15713   Click image for larger version
Name:	panel wagon carb 001.jpg
ID:	15714   Click image for larger version
Name:	panel wagon carb 006.jpg
Old 10-23-2006, 02:25 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
On the driver's side of the carb there should be a stamping number. Give us that number and we should be able to at least tell you the carb info.
Old 10-23-2006, 06:00 AM
malc's Avatar
Living At The Speed Of Life
Visually it looks like a 2GV, from 1974.
That´s the nearest I could get looking through Doug Roe´s
book, ROCHESTER Carburetors.
Old 10-23-2006, 06:11 AM
meschnebly's Avatar
I like that golf tee in that line! Wonder what year those were an option? LOL
Old 10-23-2006, 09:41 AM
Below is a photo with the number.
Yes, that's a wood screw holding the manual choke cable. The golf tee and wood screw are only 2 of the wonderfull add-ons my uncle did. They do serve the purpose, though.
Thanks for the replies,
trapperjack
The number was on the passenger side. Couldn't find anything on driver's side.
Name:	panel wagon carb 008.jpg
Old 10-23-2006, 09:50 AM
malc's Avatar
Personally I´d trash that carb and inlet manifold, find something more seviceable.
Doug Roe reckons most of the stuff on carbs that old is too far gone and not available.
Let that motor breathe.
Old 10-23-2006, 07:11 PM
curtis73's Avatar
Wiki Edits: 16
The 170 indicates that its 76 or newer. The next two digits (58) indicate the year of 1978. The next digit (1) is the emissions code. I think it means 49-state. The next digit (1) indicates the chevy motor division, and the last one (4) means probably an automatic transmission.
Rochester USUALLY followed those rules, but not always. At least they always follow the year code pretty well. Its possible that a 1978 carb sat around long enough and made its way onto a 79 engine, but that would only account for a small percentage.
Old 10-23-2006, 07:19 PM
Buick Hybrid Guy.
I'm not a numbers expert when it comes to finding stuff like this but when I need a carb rebuild kit I'd get it off the carb. I think it's a 7 or 8 digit number on there. get it cleaned up and you'll find it on the main body of the carb.
Look on the pass. side of the block where it meets the head. There will be a pad that has numbers on it. You'll be able to look up the info on the block from there.
Maby someone here has a link to a site that has all the block ID's on it?
Good luck,Scott~
curtis73's Avatar
Wiki Edits: 16
Normally I'd agree with you, but on this one, that carb is probably supplying more than enough. The heads and cam in that engine are probably so anemic that adding more won't do anything.
My guess is that its the 160-hp version at best, but probably the 125 or 140-hp, so the 380 cfms he's getting from that 2-jet is more than he needs
Old 10-23-2006, 07:21 PM
Buick Hybrid Guy.
Come on man... that Rochester carb flow's like a stop sign
Old 10-23-2006, 07:25 PM
Thanks ya'll. Getting it narrowed down. Advance auto says it's a mid 70's Chevy. No telling what my uncle did. Swapped in the 305 in 1981 from, he said a Firebird with 24,000 miles. From what I can find here, pontiac didn't make a 305, but did use some Chevy 305's. He was very excited about it having a "Pontiac" 305 as opposed to a Chevy 305 for some reason, though he did say it bolted right up. I just don't know what to look for or ask for in the way of parts. I'm not going to build it up right now, I just want a smooth running, dependable driver. The carbs gotta go though.
Champion Reman has a #3-737 for $99 that looks to be a replacement for this one. anyone have anything good or bad to say about that?
Thanks,
trapperjack
thanks for the pics malc
Old 10-23-2006, 07:43 PM
Buick Hybrid Guy.
Much past 1973 GM went into... Mono mode... They used SBC's in pontiac's and others. Smog and emmissions regulations pleagued them to the point they forogot about how to build brand specific engines.
3.8 Buick engine's went into a host of makes
SBC did too.
2.5L went into everthing from LLV (postal trucks) to Camaro's. Yuck.
Be sad to get passed in a postal truck in your 82 camaro
Anyhow....
A rebuilt carb might help.. .but I'm sure there's more problems than the carb. Golf T's don't belong as vaccume caps
Just kiddin...
Look into the health of the engine before sinking too much into it.
~Scott
Old 10-23-2006, 08:10 PM
Jmark's Avatar
The number that you cleaned off on the carb IS the number you need to use if you are going to get a kit. I NEVER order a carb kit by application for just that reason. One never knows if its the original carb or not. Using the actual carb number is the only way to go.
Hey! Golf tee's work great! So does that wood screw that holds on the choke cable! LOL (sorry, had to say it! But whatever works in a pinch!)
Mark
Old 10-23-2006, 08:47 PM
One problem I'm up against is that I just don't know where that carb came from. It may have been on the firebird when they swapped in the 305, or knowing him, he may have found it on the side of the road and stuck it in. He was driving this everyday...to WORK....until I went and picked it up. Did I mention he just turned 90? He definately has a "make it work" attitude. Why buy spark plugs when your neighbor just threw his out? He'd sand the tip a little, regap, and if it screwed in, he'd screw it in. First thing I did was change fluids and spark plugs. Had 4 different brands, and even one of those "no gap" jobs you see now. Ran like a dream after that, but carb started leaking, and accelerator pump is going, etc.
I assume all that stuff he had capped with golf tee's and vac ports looped over to the next one are for emmisions stuff this truck doesn't have?
Thanks for all the replies,
trapperjack
Old 10-24-2006, 01:28 PM
Looks like it's either a 78 or 79, at least the carb. Was there anything special about a Firebird 305 vs a Chevy 305, different heads or something? My uncle made a point of it being a "Firebird" 305, and the head mechanic at the Chevy place saved it for him and put it in himself at his home shop. Or did my uncle think that because it came from a firebird it must be souped up.
Thanks
trapperjack
305 cam carb manifold stickshift Engine 6 04-12-2005 04:46 PM
Carb for 305? Mike_82 Engine 27 01-05-2005 04:54 AM
Myth or Fact? 267 carb question YouNeverSawMeHere Engine 2 08-15-2004 02:53 PM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 11:00 AM
305 TBI to a 305 carb engine swap 91olds305 Engine 1 10-14-2002 12:48 PM
