305 chevy
hello all, i have a question i need with a cam choice,,i have 83 305 chevy ,edelbrock street master intake,holley carb, engine has an rv cam in it now, has a turbo 350 ,3.42 gears in a 85 s10 2 wheel drive blazer, im looking for a cam with "choppy" or lumpy idle, something similar to a muther thumper cam sound, but im told the muther cam is way to big for my stock little engine,im not looking for any really radical, this is a everyday cruiser, not a weekend drag racer or anything like that,,,,,,,,,just need some ideas from you all,thanks again
try comp cams extreme 4x4 cam shafts they have 4 different levels from milde to wild they have good idle choppy but not to choppy and tons of torque
305 chevy
Here is a good price on a Summit Racing camshaft. Call your order in and ask the sales rep about new valve springs for this camshaft. Summit Racing SUM-K00052 - Summit Racing Street & Strip® Cam Kits - Overview - SummitRacing.com
Any of the cams that will give you the choppy racy idle (thumpr cam included) will require a 3500-4000 stall and big gears when used in a 305CID motor. The bigger the tires the more gear needed.
Big cams in small CID motors need to rev (gears) and do not like a stock torque converter. Any 305 with a cam will not get busy until 3000+ rpm. Isky cam 201268 268-268 224-224 .450" .450" 107lsa Degree this cam in and install on a verified 102° intake C/L Needs a valve spring swap for max performance. get a "3500 stall" (rated) and get some gears 4.10+. It wil go like hell and sound bad just like you want. Ditch the old obsolete intake manifold and get a edelbrock performer rpm dual plane. The distributor will need to be recurved. A stock distributor timing curve will not work well with this type of cam. The recurve is not hard to do. Search my posts. this is how you make these rough idle cams work on the street. If you follow this outline you will get the sound you want and impressive results. Isky 268 Mega cam cam card 201268 http://iskycams.com/timingchart.php?..._number=200268 Last edited by F-BIRD'88; 10-20-2012 at 02:54 PM. |
| 350 chevy and a 305 chevy | redwine | Hotrodding Basics | 1 | 01-10-2012 09:09 PM |
| Chevy 305 | tanman10069 | Engine | 7 | 07-23-2007 03:14 PM |
| Will this work? Chevy 305 Throttle Body w/ Chevy 350 | aberg12012 | Engine | 9 | 05-07-2004 12:28 AM |
| 1986 305 chevy vs. 1987 305 chevy new style small block | mtinsley | Engine | 2 | 08-22-2003 11:55 AM |
| 85 chevy 305 heads on an 89 TBI chevy 350? | jazzguitar | Engine | 4 | 11-03-2002 04:11 AM |
