305 chevy sluggish - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 09:31 AM
305 chevy sluggish
Hello any ideas on how i can pep up a 1979 305 motor i cant even get a chirp from the tires. I have a 350 a/t and 348 gears.
Old 01-26-2013, 09:36 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Have you checked the timing and advance mechanisms? Do the work, is timing correct?
Is the exhaust breathing freely? Could be plugged at the cat.
Engine could be tired, but for sure if it is a stock 2 barrel engine the cam is puny .
Not to mention the cam timing is probably retarded for emissions.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
ratrodheritage (01-26-2013)
Old 01-26-2013, 09:51 AM
It has a lopey mean sounding cam, shorty headers 4 bbl carter carb, passing gear works on q,The timing and vacuum seem to be good it has a nice curve 10 BTC and 40BTC at 2500 rpm gets good accel but wont turn the tires.
Old 01-26-2013, 09:53 AM
Its installed in a 32 chevy coupe that weighs 2700 lbs the rear diff out of a 73 -80 vette.
Old 01-26-2013, 11:23 AM
LATECH's Avatar
Lumpy lopey most likely means cam is bleeding off too much compression at low rpms. The thumper cams are known for that. They sound cool...but thats about it.
You could put a 2500 stall in it, that would liven it up.
Old 01-26-2013, 03:44 PM
lg1969's Avatar
Google "Tunnel Ram 406"
First, you did not mention the type of car you are driving. If the 305 is stock and the tranny and converter is all original, you will never spin the tires. The work on a 305 will be so much you better off of getting a 350 from a junk yard and sell the 305. 350 are a dime a dozen. Don't bother spending money on aftermarket auto parts.
Old 01-27-2013, 08:43 AM
I think i'll agree that the305 is a dog. Had one in my nova when i bought it new. Latter years i tried everthing to get that thing to run. Sold it to make room for a 355 motor and it realy ran good. I then took the rear and put 3.42 posi in, and 200 4r tranny. Then it turned out better. Now i'm putting 3.73 gears and a better torq converter. Good, better, best. never let it rest. MY motto for a hot rod. ...
Old 01-27-2013, 08:45 AM
vinniekq2's Avatar
late 70s and early 80s sbc s were nothing to write about.All the parts are low performance.When I bought my 81 vette the original engine was warmed over,cam,holley manifold,holley carb,small tube headers. I test drove the car,felt ok,bought it.Tuned it,enhanced the carb,upgraded the ignition etc. The best combination of tune netted 205 horse power and almost 280 pounds torque at the wheels.
After thinking of what I could use from the original engine,I ended up replacing everything. I went a little over board.
Point Im making though,that 79 305 does not have a lot of potential,at least not for cheap.
Old 01-27-2013, 11:55 AM
Man you have to do alot to those little cu inch motors to get any real power. there is no substitute for cu inches. Not to mention, the high the horse power, higher the revolution, the greater the wear. there is also a comfort side also. I like my power and get up and go, but there is the comfort i like when i drive. That is why i stuck with a automatilc with four forward gears. That overdrive gives you alot of options for gear ratio.
Old 01-27-2013, 12:05 PM
Wow
Now thats why I joined hot rodders thank you to everyone for the sincerely great ideas. And the gears are out of a 73-80 vette with the 350 trans it feels like it wants to shift again at 55 mph.
'90 Chevy sluggish, hesitating jerryofar Engine 6 11-14-2011 01:53 PM
72 chevy with sluggish rebuilt 350? rreruption Engine 20 10-16-2007 08:29 PM
sluggish Matts99Sierra Engine 2 02-19-2005 07:50 PM
Running Sluggish! Fragzem Engine 3 02-24-2004 12:11 PM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 11:55 AM
