305 Combo what do you think? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-29-2010, 09:18 PM
I really wish there was a smiley for roflmfao! Thank you for correcting me about the differences between the two. Both cars can be made into very angry track machines. cobalt, isn't the Buick GN a g-body? I would give a left testicle to have one of those. Amazing cars. I think it's safe to say that due to the age of 80's cars now, along with the massive change of engine technology, they're all rusty old dinosaurs destine for the scap yard. when thinking of a g-body or an 3rd gen f body, All i see are bad mullets and zz top music videos. BUT, I love my 3rd gen, and I do like g-bodies. the cars have an amazing aftermarket, and thats what really counts in my book.
  #32 (permalink)
Old 06-29-2010, 09:21 PM
speaking of wet noodles, they can handle really well if the were designed like that. AC Cobra anyone?
  #33 (permalink)
Old 06-29-2010, 10:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sure- it also had a decent rearend and a turbo engine that could be made to run.
Just like their were third gen F-body Formula Firehawks, some had a Dana 44 rearend and a decent engine.
  #34 (permalink)
Old 06-29-2010, 10:18 PM
very true. i'm lucky to have a 305 and a 700r4 with a solid body. i would shoot myself if a had a v6 or an iron duke. i really hate the small ring ten bolt in my car. blew it up with the stock engine.
  #35 (permalink)
Old 06-29-2010, 10:19 PM
well, oddballs aside, both cars have mad potential and are cheap to build. thats what i love about older gm cars
  #36 (permalink)
Old 06-29-2010, 10:23 PM
"Fact is, they're BOTH **** ty unless a lot of mods are made. And neither would be my first choice for a street prowler if a tight budget was involved."
Exactly the point, making anything this old street legal and road worthy will break the budget and schedule for a street rod, but the F-body has 2 kiss-of-death problems no other car has:
1) the heater core, the first part bolted into the car, everything inside the car has to be removed to replace it, a MAJOR PITA.
2) the fuel tank, with 20 - 30 years of rust & junk in the tank it needs to be replaced. Ever replace a fuel tank in an 3rd gen F-body? You'll never do it a second time, neither will any shop you try to hire and you need a twin post bay lift to do it. Just not worth the bother.
" All i see are bad mullets and zz top music videos."
Rick James in Jerri-Curl and cheap leather from 'Super Freak'
Michael Knight with a disco hair-helmet and Member's Only jacket
Metro sexual pink, mauve and teal from Miami Vice
Big hair, spandex and nipple rings from any 80's metal band
Michael Jackson's glove
Mel Gibson from 'Lethal Weapon'
the list is endless, thanks for the ear worm in my head.
  #37 (permalink)
Old 06-29-2010, 11:14 PM
Silverback's Avatar
Boost Retard
Actually, the heater core on them is _really_ easy to get to, just remove the hush pannel and bottom of the box and swap... I think I did it in like an hour and a half the last time, and most of that time was trying to get the heater hoses disconnected.
You want a headache, try doing it in a fox chassis ford (mustang, t-bird, cougar, LTD, marquis, fairmont...), that one really is like you describe, I'm not kidding, the whole dash has to be removed from the firewall, steering column dropped to make room...
The fuel tank pretty much does suck in them, but I've never seen one with an issue with rust. Usually the problem is the fuel pump, and if you're going to be doing extensive work to it as far as I'm concerned you might as well make an access door to get to it rather than drop the tank.
  #38 (permalink)
Old 06-29-2010, 11:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You are in as good a shape as one could reasonably expect- just some HP, a diff and some stiffening away from nirvana!
  #39 (permalink)
Old 06-30-2010, 12:10 AM
"Actually, the heater core on them is _really_ easy to get to, just remove the hush pannel and bottom of the box and swap... I think I did it in like an hour and a half the last time, and most of that time was trying to get the heater hoses disconnected."
Thanks, learn something new everyday.
Too bad it's a day late & a dollar short, I haven't seen one of these in the shop in 10+ years.
"The fuel tank pretty much does suck in them, but I've never seen one with an issue with rust. Usually the problem is the fuel pump, and if you're going to be doing extensive work to it as far as I'm concerned you might as well make an access door to get to it rather than drop the tank."
For collision work it's R&R, on the frame rack it's a massive PITA. All the ones that I've dealt with had attached filler necks, apparently there are ones with removable necks.
If you read the article from CarCraft, thrash in the tank was their problem, it was running out of gas over 4000 and ran flat after that. Looked really stupid for a magazine project car, all that money and time for nothing.
  #40 (permalink)
Old 06-30-2010, 06:03 PM
goldenbullet44's Avatar
User that registered
I'm grabbing a t-56 tranny for my car. Also gonna try to grab a stronger rear end for it.
  #41 (permalink)
Old 06-30-2010, 08:30 PM
asbolutely my point! I bought an lt1 take out from a 95 impala ss for $500 and I'm planning on 415-425 at the crank with 040 over bore and stock heads... yep the rear is a big concern of mine, but, when i blow it up again, I'll put something stonger in it. stiffening's a no brainer on the car, but thanks for reminding me! i always forget about that.
When I had to do the heater core on my car, the center counsel had to come out, dropped the steering wheel down, unbolted the dash and swung it about 45* out from the passenger side. BIG PITA! Never did a tank in it...yet. but i'm switching to a fourth gen plastic tank for the efi. i think its also 2 gallons bigger.
  #42 (permalink)
Old 06-30-2010, 08:33 PM
GOOD MAN!! t56 all the way! you can get the whole setup for cheap on ebay now days. a stronger rear end may even be more expensive than the trans. You can also build the stock diff pretty strong, they'll take some real abuse with some work. I may even do that.
  #43 (permalink)
Old 06-30-2010, 09:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well... I'll just say that I think the cost for everything needed to "beef up" that puny rear end would be money much better spent on an entirely different unit. But it's your ride and your call.
Good luck whatever you decide.
  #44 (permalink)
Old 06-30-2010, 11:16 PM
A brand new road test of a 1991 Trans Am nets the same numbers as the 150,000 mile road test at CarCraft, not too bad at all.
Brand new road test
  #45 (permalink)
Old 06-30-2010, 11:26 PM
Silverback's Avatar
Boost Retard
$500 for an LT1 intake off of a b-body? the last b-body LT1 that I got I paid $100 for the whole thing, throttle body to exhaust manifolds...
Opinions on this SBC combo coony278 Engine 5 11-16-2008 12:47 PM
My 1984 caprice 305 - 700R4 MRGM General Rodding Tech 23 03-08-2005 01:13 PM
350 to 305 swap 78Z Engine 10 02-06-2005 02:42 AM
Silverado Blazer 305 Project william27103 Suspension - Brakes - Steering 1 10-18-2004 05:16 PM
