-   -   305 compression ratio (http://www.hotrodders.com/forum/305-compression-ratio-37483.html)
skiffer 04-10-2004 07:56 AM
Can anyone tell me the compression ratio of a 84 305 chevy with stock full dish pistons and 58cc heads?--thanks
DoubleVision 04-10-2004 08:06 AM
8.5:1 with the factory .028 thickness head gasket. with a aftermarket fel pro .041 gasket about 8.3:1
skiffer 04-10-2004 08:23 AM
thanks double v
dirtyfingers 12-13-2012 06:33 PM
305 heads
some one asked about 305 58 cc heads on stock engine with dished pistons,will this be the same for dished pistons without valve reliefs, Trying to run on low octane gas. I have a stock 305 bore and 58 cc also. thank's
