Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 compression testing
Old 11-07-2012, 10:38 AM
allansmith859 allansmith859 is offline
OK Im getting confused. Im trying to see if I can use this 305 engine. Its the block and rotating assembly. The guy who had it said HE THOUGHT one of the rings was bad cause of a little smoke out the exhaust. That could be from a valve seal. I was asking if I could just bolt ANY heads on and take a guage, screw it into the spark plug hole and turn the engine over and see what it reads for every cylinder. If I do that what can I learn about every cylinder.
