Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 compression testing
Old 11-07-2012, 01:42 PM
allansmith859 allansmith859 is offline
The cylinder walls look great. There is a very little amount of surface rust that has appeard in two of the cylinders at the very top but I can clean that off. There is no lip at all they look very good. If I put these cylinder heads on this block which is bored .060 over with flat top pistons (head # 14101083). Would it be a good little street motor depending on cam choice and other applications??
