305 crank in a 350 motor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-17-2008, 09:38 PM
It'll run. I built a budget 355 with a stock 305 crank years ago and it had a slight vibration at 2500 rpms but ran strong. I spun it to 6500 rpm many times and it held together. Fire it up!
  #17 (permalink)
Old 03-18-2008, 06:45 AM
6426yy's Avatar
I've been running one in my truck for over a year. It doesn't vibrate any worse than a stock engine. I've driven this truck nearly everyday. Yesterday I hauled three full loads of gravel that weighed over 2500lbs each. So it is a work truck, but it rarely sees anything over 5 grand.
If it's a budget build run it, If it shakes your fillings out... well you know what
  #18 (permalink)
Old 03-18-2008, 12:10 PM
Dale
Just run it. I built a 262 with a 307 crank shaft in it and never worried about the balance. I never noticed any vibration in it and I ran it hard. Balanced perfectly is for race engines daily drivers are less picky. Dale
  #19 (permalink)
Old 03-18-2008, 01:18 PM
It all depends on how far out of balance the assembly is, in my experience running a 305 crank in a 355 worked OK for what that engine needed to do. But...., I've also seen a friend build a 12-1 406 with 5.7rods and he never had that assembly balanced- it shook itself to death.
305 head on a 350 sbc Trav Engine 41 04-13-2013 08:30 AM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Stock 350 with 305 truck heads? CrazyT Engine 3 08-04-2009 01:15 PM
can i turn a 305 into a 350??? my 1st car is a nova Engine 5 04-21-2007 01:07 PM
Piston preference for a 350 with 305 heads Old School Baja Engine 0 01-07-2007 07:23 AM
