Is a 305 Crank the same as a 350????? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-15-2012, 03:26 PM
F-BIRD'88's Avatar
Yada Yada Yada
Originally Posted by allansmith859
Let me ask you this. The heads that were on the engine were HO. would they be worth using and have sent in and checked for cracks and cleaned up?
if they are the 4416 castings and you port them and install larger 1.94 x 1.60 valves ya they work very well on 350's. If you do it for under $500 total cost
its a good deal. Its not worth it if you have to pay someone else to do the porting.
its a DIY thing. Can you (or better yet wlll you) do that?
In stock form these 4416 heads are modest stock low perf heads but they have a good power potential in ported form.
You need to get a estimate first.
new assembled high performance SBC cylinder heads at about $800 and up.
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
BBC crank casting numbers... which is the better crank Rush Hour Racing Engine 2 02-24-2011 10:55 PM
ground 400 crank or new 383 crank? backyard71nova Engine 10 09-12-2007 06:13 PM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 10:54 AM
4ma crank vs stock clevo crank carnell Engine 1 08-17-2003 05:56 AM
