Is a 305 Crank the same as a 350?????
Depends on the year, some early 350 cranks were small journal, and came steel, cast and forged. IIRC, there were no forged 305 cranks, but all were large journal. Here's some data.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Ok this is what I found out. This crank (3932442) is the one I pulled out of my 85 Z-28 motor (305), but its also the same crank that is in my 350 engine.
So since they are both the same could I use the one out of the 305 Here is the info for the two cranks: 1969 - 85 (The engine was in a 1973 vehicle) The crank was used in 305 and 350's and in 1979 -1982 267 cid Cast Nodular Iron Large journals 2 peice rear main seal |
The balance is different for each different motor.
the cost to correct the balance is moe than the cost of a usable 350 core+ the regrind. Someone will buy your 305 block and crank to build a 305. |
So I guess Im better off selling the 305 block and the 305 crank and keeping the 350 with its crank. I planned on building the 350 but just wanted to know if the two cranks would interchange.
Thanks guys |
Well I actually planned on building the 305 in the first place but after doing research people say its a waste of time to mess with the 305, is that true.
A 400hp spanking street strip 305 w 10.5:1 compression and ported big valve 305HO heads is not hard to build. A spanking B&M blown 450hp low compression ratio 305 is not hard to build. These 305 engines want to rev high and when souped up want a steep gear and converter. Thats the biggest difference between a built up 305 and 350 of comparable power output. same cat just a different way of skinning it. A built 350 gets it done too. Last edited by F-BIRD'88; 03-09-2012 at 10:57 AM. |
Let me ask you this. The heads that were on the engine were HO. would they be worth using and have sent in and checked for cracks and cleaned up?
Although factory GM 305 and 350 cast cranks have the same casting number, they are "balanced" differently. A 305 application crank has a target bob weight of 1600 grams, while a 350 application crank has a target bob weight of 1850 grams. These are factory numbers, aftermarket balancing is much more accurate.
| whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? | onlychevy | Hotrodding Basics | 14 | 12-28-2012 07:27 AM |
| BBC crank casting numbers... which is the better crank | Rush Hour Racing | Engine | 2 | 02-24-2011 10:55 PM |
| ground 400 crank or new 383 crank? | backyard71nova | Engine | 10 | 09-12-2007 06:13 PM |
| Scat 9000 crank VS stock 400 crank? | MOORESPEED | Engine | 5 | 03-03-2005 10:54 AM |
| 4ma crank vs stock clevo crank | carnell | Engine | 1 | 08-17-2003 05:56 AM |
