305 distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2002, 04:31 AM
beetle9's Avatar
Post 305 distributor
I am getting ready to install a 305 in my car and notice there is no vacumn advance on the distributor. I see no evidence on one having ever been there. It seems like 305 distributors are different and i saw this post before, but can't find it. Can anyone help.
thanks
Old 11-10-2002, 04:53 AM
dmorris1200's Avatar
doesn't play well with others
Post
[quote]All spark timing changes in the 1981 distributors are done electronically by the ECM. No vacuum or mechanical advance is used. <hr></blockquote>
I got this from my old camaro chilton manual. It says that their electronic distributors only had vacuum advance from 1975 to 1980. Maybe the distributor you have is 1981 or newer. Just a guess, don't do much chevy work.
If this info is correct I would want a '75 to '80 distributor so my timing is controlled correctly without a ECM. I know on Fords we always look for the old Duraspark system for this reason.
[ November 10, 2002: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 11-10-2002, 07:49 AM
Post
you got a coputer controlled distributor...which means it probably also has a coputer controlled carb..( no screws for adjustment and a plug with if i remember correctly 4 or 5 wires on the carb...my advise:; go get yourself an older non computer carb and dist.
Old 11-10-2002, 12:39 PM
beetle9's Avatar
Wink
I'm gettin' the picture, dump the computer controlled junk and get back to basics. I'm heading for ebay as we speak and thanks.
