305 and Edelbrock 1406 carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2013, 04:14 PM
I need the collective assistance of the carburater gurus ....ii have an unusual problem with the engine and carb combination above. With the motor at operating temp and trans in neutral, motor seems to jump in rpm as throttle is advanced. While SLOWLY opening linkage from idle the engine will SLOWLY increase rpm...then about 1/4 inch off idle (no tach) the engine seems to jump up as if it suddenly gets a surge of gas. This is not noticable under load, but im sure its happening while driving as well. Already checked for vaccum leak and manifold leaks so its not that...just cant figure out the surge !
Any ideas ??????
Edelbrock 1406 carb hard to start when hot 64Eldorado Engine 3 07-25-2011 11:06 AM
Another edelbrock 1406 carb question 99 to Life Engine 9 06-28-2011 04:32 PM
1406 edelbrock carb help hddave1 Hotrodding Basics 4 04-30-2011 01:44 PM
1406 edelbrock carb electric chock hook-up mferris72 Engine 1 09-03-2004 06:41 PM
edelbrock carb 1406 or 1411? MopaRV Engine 7 07-30-2003 01:07 AM
