#61
You can contact someone like summit they have them from like $100 and up. You will have to call them give them all your engine specs and i mean all. and they can hook you up with what you need. it will be ground to your engine specs tell them what you are trying to do and get from your engine and they can help. This is not only through summit just about anyone with cams can have this done for you all they need is all of your info on your motor and stuff. Hope this helps. Cole Register now (free) or login to remove ads |
#62
oh ok thanks for the info so the xe274h comp cam would be the better choice for my build??? |
#63
Heres a couple of places that i know people have used that can grind whatever you need.http://www.bulletcams.com/ . http://www.cammotion.com/ . Cam motion just did one for a friend of mine he got a mechanical hyd special grind lifters and all for $254 just so you will know these people here can grind one for any application. You will have to call or email them with all your info and they can do this for you. Build a cam that will work for you. Hope this helps.Either one of these can do it but Bullet does a better job with chevy engines so i have been told. Cole
#64
thanks alot bro...i will call them and see what can they do...thanks jerry |
| Thread Tools | Search this Thread |
| Similar Threads for: "305 engine help?" | ||||
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
| 305 marine engine | fullthrottle | Engine | 16 | 03-12-2007 09:38 PM |
| Valve adjustment 305 chev engine | Oneshot | Engine | 2 | 09-21-2003 08:22 AM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 1 | 10-14-2002 11:48 AM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 0 | 10-14-2002 10:10 AM |
