Hi chevy friends,
my bone stock, mint Caprice Classic Brougham, (V8, 305?)"89 starts with a blue smoke after a nightlong standstill. I guess thats the valve stem seals; I'm living in Dominican Republic and nobody around here has the recommended tool to change the seals. Question: is there a way to change them without that special tool? (I don't want to take the heads of) Is this a very difficult job? Following Haynes or chilton manual it looks pretty easy. Any help? Suggestions? Pablo <a href="http://www.casalindaonline.com" target="_blank">web page</a> casalinda@codetel.net.do [code] </pre><hr></blockquote> |
thanks, Hotrod, but there is no such thing as Autozone down here in Domincan Republic. you don't know how lucky you are in the US, just drivin to the next speed shop, buy the part or tool and that's that.
Anyhow, thanks for the reply, will try my luck. Maybe it's even better to take the heads off and check heads and bore and so on. pablo |
Dont know if summit delivers there but heres the address summitracing.com they have the tool you need.if you dont have a air compressor take a 1/4 inch cotton rope about 8 feet stuff it in your cylinder leaving about foot hanging out turn motor over by hand till piston smashes the rope agaist the valves then you can remove the springs.this will hold the valves in place.hope this helps.(wrenchturner)
Valve seal replacement
Just to confirm that the comment about the cotton rope is good advice and really important and easy to do. Make sure when you get an air compressor that it's big enough to maintain good pressure because you'll get a little leak-down while the air's holding the valve closed so the pressure's got to be maintained well. There are several different designs for the lever that you'll use to compress the valve spring, remove the keepers and retainer, etc. The simplest one is just a stamped steel lever with a slot in the end and it's very hard to use and requires strength in your arms. Go for a tool that is adjustable and provides good lever action...it makes it much easier when you're reassembling the valve spring, retainer, keeper.
Quick 58 |
