305, good, bad,? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-04-2006, 03:08 AM
What about the little Holley 450cfm 4bbl (mec. 2nds)? Would that be 2 small? Or would the 500cfm 2bbl be a better carb?
I have 1 flowmaster allready, and I like the sound. I had not heard of the bad flow problem before is it a big problem?
  #17 (permalink)
Old 05-04-2006, 03:40 AM
as always...here we go again with "which carb is best"....my answer is "which carb tuner" is best....tuning for a heavy vehicle that is going to constantly want to tip into the secondaries due to Hg drop from high motor load driving normal
For mpg best, with any carb brand, simple enough to mount a vacuum guage on the column in the truck so you can train you size 12 boot to accelerate so that the Hg doesn't drop below 10-12Hg....and tune for the highest Hg at 70mph
depends on the weight and gears and tire size and how much intown versus hwy to decide "if" you want smaller primaries and do you want a 4V carb,
geargrinder,
I disagree with alot of the content of recent posts, suggest you study build ups for 4x4 trucks....
  #18 (permalink)
Old 05-04-2006, 05:00 AM
geargrinder, your 450cfm post showed up after my last post,
"all has to work together"= you pick the carb to go with "what" cam/tri-Y's/gears/wt/etc. and depending on intown or hwy %
small (?) primaries on the 450 in town can hurt (13 and 23mpg post above with a q-jet in a 3400 lb car....you are heavier) and helps on the hwy
set your priority, MPG or power, intown or hwy, middle ground for all is a 450-500 cfm 2V (it is a 2V from the factory in a truck for good reason)
  #19 (permalink)
Old 05-04-2006, 12:23 PM
Gotcha! Thanks for all the input on this guys. I'm new to the hole "better milage" thing so I feel like I'm flowndering around alittle on this one. I'm more interested in around town milage without it being a dog than anything else.
  #20 (permalink)
Old 05-04-2006, 12:32 PM
Originally Posted by red65mustang
geargrinder,
Funny U should say that, I have been doing the 4x4 thing for the last 10 years. And I'm not sure how ALL the 4xers are doing it, but I know for me and my old crowd ALL THE POWER U can get, and keeping it runnin' @ ANY angle/bounce is the key. That SUCKS dead dinos like theres no tommorow I had a 454 in my last trail rig that pulled hard from 1000rpm all the way to 5500rpm, it rocked! But it got 5-6mpg
Stainless Steel Headers good or bad jjtrains84 Engine 5 04-11-2010 10:15 PM
350 heads on a 305, good idea??? STATUTORY GRAPE Engine 7 11-29-2005 06:06 PM
bad miss in my 305 Tysroc Engine 4 10-08-2003 09:58 PM
RUSTBUSTERS....Good or Bad?? 40 Body - Exterior 4 12-31-2002 11:11 PM
