Thread Tools Search this Thread share on Facebook
  #16
Old 02-19-2009, 12:10 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by Torque454
Engine is on the stand cant really whack it unless i take it off the stand and hang it on the hoist. Not sure how good of an idea that is. lol. I pried the crank all the way back and then all the way forwards to measure the end play. Would that help reset it? Or should i just give it a whack before I put it in the truck? Wouldnt be able to check the clearance then, tho.
Smacking the crank with rubber deadblow hammer to seat the thrust bearing is normally done. I use a dial indicator with magnetic base to check end play. Can be done with pan on or off. Smack it before you install.
Register now (free) or login to remove ads
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "305 Harmonic Balancer"
ThreadThread StarterForumRepliesLast Post
What the ***** is wrong with my timing cover/ harmonic balancer!!!sexypizzamanEngine5610-28-2008 03:49 AM
SBC harmonic balancer installv8hedEngine1408-17-2008 04:10 PM
Harmonic Balancer helpsexypizzamanEngine502-11-2008 04:21 PM
283 Harmonic BalancerJamesDEngine2903-14-2007 05:36 PM
sbc harmonic balancer84cutlassEngine204-10-2006 08:38 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
