Thread Tools Search this Thread share on Facebook
  #1
Old 02-27-2009, 07:04 PM
Torque454 Torque454 is offline
305 Harmonic Balancer - Again
Got a new balancer, now im trying to get it installed. Purchased a long grade 8 bolt and a box of washers (all the correct size of course) and am using it to press the balancer on. The balancer doesnt go on enough to use the normal bolt to push it on with and plus i wanted some extra length so it would go further in the threads so maybe they wouldnt pull out of the crank. Id be screwed, then. Engine is already in the truck now. Anyways i am using the water pump pulley off of a 454, which i dont think is the problem but you never know. It appears the balancer needs to come in another 1/4" But i cant get it to move anymore. The torque on that bolt is already at 80ft lb and its not pushing on anymore. Do i need to see if i can rent that special tool or what? (I would think it would work the same way as the bolt trick that i am using) Im getting a lil crabby with this thing. Guess this is why people hate 305s. I am wishing i had bought a Vortec 4.3 instead.
Register now (free) or login to remove ads
Old 02-27-2009, 07:16 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
is it bottomed out? 65 ft lbs is what it should be toque at not 80 your gonna break . cole
Old 02-27-2009, 07:18 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
You need to shim the pump pulley out or get the correct one. 80ft.lbs it should be bottomed out against the crank.
Old 02-27-2009, 07:20 PM
Yea i figured. Cheap harbor freight torque wrench could be inaccurate too. I think I read 85 ft lb on that bolt in some cases but i wasnt gonna push it any further than 80. Thats why i stopped there. No i dont think its bottomed out but i can try a few more washers between the face and the head of the bolt and try it out.
Old 02-27-2009, 07:23 PM
Is it possible the BB pulley is the problem, and not the balancer being out too far?
Old 02-27-2009, 07:27 PM
eloc431962's Avatar
Wiki Edits: 37
like ssedan64 says shim the pump pully out or the right pump would be best. cole
Old 02-27-2009, 07:28 PM
Its the right pump, just might not be the right pulley.
Old 02-27-2009, 07:31 PM
eloc431962's Avatar
Wiki Edits: 37
yea i would be trying to find the right pulley.you might have to try a few.i have been there with the pulley search myself. cole
Old 02-27-2009, 08:05 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
The Big Block pulley is the problem, they are not the same as small block.
Old 03-08-2009, 10:54 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
i keep a longer grade 8 bolt for the balancer installation here
at first use spacer nuts and or washers
then once you gt it on pretty good you can go to the stock bolt and finish it up
with the impact gun
never once ever stripped one and ive removed and put on tens and tens of them over the years
Old 03-08-2009, 11:31 PM
I've got it on now, i borrowed a puller from oreillys.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "305 Harmonic Balancer - Again"
ThreadThread StarterForumRepliesLast Post
305 Harmonic BalancerTorque454Engine1502-19-2009 12:10 AM
What the ***** is wrong with my timing cover/ harmonic balancer!!!sexypizzamanEngine5610-28-2008 03:49 AM
SBC harmonic balancer installv8hedEngine1408-17-2008 04:10 PM
Harmonic Balancer helpsexypizzamanEngine502-11-2008 04:21 PM
283 Harmonic BalancerJamesDEngine2903-14-2007 05:36 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
