Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-20-2005, 11:52 AM
savman1 savman1 is offline
305 head on 350
I've been in the tech area alot lately at a local track. They have a pretty much strictly stock class there. The rule says must run an open chamber heads. One of the gray areas has been a 305 head on a 350. This is what the track says. The 305 chamber fits the cylinder on a 305, but on a 350 it overlaps the cylinder, and makes it a closed chamber. Is that so? I know a double humped head is a closed chamber head, but some of the guys being dq'd say that the 305 head isn't a closed chamber head, but rather a small chambered head. The track says that's the case on a 305, but it becomes a closed chamber on a 350. The track also says a 350 head such as a 487 won't run good at all on a 305. Is that so? Also some of the guys that run 350's are alledging that the some of the guys running blocks with a 305 number on them and a 305 head could be boring them out to 350. Now I know that the catings in those 2 blocks are different and the cylinder walls would be too thin, but some of them are claming that some of the 305 blocks can be bored out to a 350. Is this true?
I've seen things like this before. 78-86 GM passenger cars with a metric frame are supposed to be automatic, a no disc brakes on the back. That's what most people say anyway. Well, my friend has a 78 Monte Carlo that come stock with a standard tranny in it. The Floorboard is prepared for it and everything. My neighbor has a Buick Grand National, and it has stock disc brakes on it. By the way, that's a V6, and it will fly. Could possibly an early 305 have been just a smaller bored 350?
Old 10-20-2005, 12:04 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: 305 head on 350
A 305 head on a 350 is just a smaller combustion chamber. These heads will raise your compression ratio at the expense of more quench area, smaller valves and smaller port "Windows". A 350 head on a 305 will lower your already low compression ratio and you won't be able to pull a fat girl off a tricycle.
NO WAY can a 305 be bored to 4" 350 bore. You may possibly come across a mis-cast block no. ( I've seen quite a few oddities ) but no big bore jobs on 305 blocks.
Old 09-08-2006, 06:15 AM
runn141's Avatar
runn141 runn141 is offline
1/20/09 the end of an error
re: 305 head on 350
no chevrolet motor i know of can be bored more than .060 except the 283's. 305 had 2 high compression heads #416 and #601 both 1.84 1.50 valves. #601 had 53cc chambers but the #416 had 58cc and an intake flow of a 350 head. i took a set of #416 heads, had the intake valve seat cut to 1.94 from 1.84 and done a gasket match port job and bowl blended it. i put them on a 358 it gave it 11.3 to 1 compression. believe it or not i could retard the timing and have no detonation on pump gas. and i know for sure because i kept a close on the plugs.but the #416 is a better chamber design for a 350, i think.
Old 10-15-2006, 09:00 PM
77formula 77formula is offline
re: 305 head on 350
#416 heads, huh, what would be the full casting number on these heads. i have put 305 heads on my 350, just looking to up the compression ratio. i was just wondering if i had a good set of 305 heads???????
Old 10-15-2006, 09:18 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Ford Service Technician
re: 305 head on 350
An open chamber head is an open chamber head. The way it fits the bore has nothing to do with the chamber design. .
Once again, this is incorrect information. The 305 head IS an open chamber head. It is an open chamber head on a 305, and I could bolt it on a 400 SBC, and it would STILL be an open chamber head. What it does it boost the CR of the 350, the same way a closed chamber 350 head would. It simply does this by having a smaller chamber volume, while remaining open. I'd suggest having a good look at the rulebook for that track/class. If there is a rule specifically for the 305 head on a 350, you cannot argue. If there is not, and it simply states that you must run a stock, open chamber GM head, the 305 heads should pass tech
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "305 head on 350"
350 to 305 swap 78Z Engine 10 02-06-2005 01:42 AM
305 or 350? Miserlou57 Engine 4 02-05-2005 08:13 PM
305 head on 350 Houman SS '70 Engine 11 02-02-2005 05:51 AM
Distributor Question - 1985 305 and 1975 350 Fragzem Electrical 3 10-28-2003 10:07 PM
305 vortec heads on a 350 tonylsg Engine 13 09-21-2003 05:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
