305 head on a 350 sbc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-13-2005, 12:26 PM
sbchevfreak's Avatar
Licenced Automotive Technician
3970126 -- 67-79 --327/350 -- 1.71/1.5
BTW, those are 2 bbl heads..... not so good for performance. If you're looking for budget performance, i'd go, as stated earlier, with the vortec heads. Minimal upgrades will produce very satisfactory results. Just have them magnafluxed, and then have the heads machined for higher lif #'s, as the vortecs can only handle about .450-.470 stock(I think those #'s are right).
  #17 (permalink)
Old 07-13-2005, 01:27 PM
I've got a set of heads off of a 1976 262 engine on one of my 350s that have been ported and bowl blended, chamber deshrouded and 1.94 intake valves installed. With a small comp cam Xtreme energy 4X4 cam and performer intake, holley 600. The engine will smolder the tires through 1st and second and I shift it at 6K. No hestitations, excellent throttle response. The chambers measured exactly 64cc's after the deshrouding and larger valves were installed, originally with the smaller valves and stock chamber size they were 50 or 55cc's I think. The port shape is very very similar to the 882 casting. Also these are the heavy castings which are very durable, unlike most of the 305 engine designs. I can get the casting numbers if anyone is interested. Look for 1976 chevy novas and simlar-most of these cars had the 262 engine. Bob
  #18 (permalink)
Old 07-13-2005, 02:10 PM
1964chevelle's Avatar
its not pink its ember red
the 305 heads on a 350 will not produce the right flame travel to make power in the top end. im running 461 double humps on my 350 try finding those or 462 good heads if not i have some 882 in my garage you can buy
  #19 (permalink)
Old 07-13-2005, 09:04 PM
Mad Maggot's Avatar
The lean mean donut machine
The best 305 heads are casting number 14014416
This version has larger 165cc intake runners, a taller short side radius, and 58cc chambers. Stock valve size is 1.84/1.50, but if you do some significant deshrouding, you can fit 1.94/1.60 valves in.
Give these heads some mild port work and a good 3 angle valve grind and you should make great power up to 5200 RPM with a decent cam in a 350. There is a good porting guide for the 305 heads that any beginner can do at http://www.sa-motorsports.com/diyport.shtm If you have the time to do this, it will significantly boost your performance while costing only peanuts.
My very first port job was done with these heads, and I got them to flow 213 cfm without a lot of grinding.
  #20 (permalink)
Old 07-13-2005, 11:15 PM
GoneNova/406's Avatar
a good choice would be the 87' and up 305/350 14102193,1.94/1.50 valves.the junk yards or loacl papers should be a good source for these heads and you may not have to do anything to them except a valve job and if you do the work that'll be cheap.take the covers off and check the #'s.you won't lose anything on top with these heads.
  #21 (permalink)
Old 03-18-2009, 01:56 AM
jasont/a83's Avatar
slave to engines
hey sounds like my engine ... i cant rev past 5000 same heads
  #22 (permalink)
Old 03-18-2009, 04:31 AM
DoubleVision's Avatar
This thread is 6 years old.
  #23 (permalink)
Old 03-18-2009, 08:54 AM
It really dosnt matter how old the tread is , its still good info and helps with not having a repost witch I bet agrevates you older guy even more
  #24 (permalink)
Old 03-18-2009, 09:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by jasont/a83
...i cant rev past 5000 same heads
Even w/1.72" intake valves, it should rev past 5K rpm- in neutral!
  #25 (permalink)
Old 03-23-2009, 09:28 AM
305 heads on 350 block
Im going with 305 58cc Heads on my 350, would appreciate what would be the best combination of cam, intake and carburator.
  #26 (permalink)
Old 06-02-2010, 07:01 AM
Originally Posted by Trav
After hearing ppl saying so much sh#t about putting 305 heads on a 350 will boast compression depending on pistons.. and gain some low end.. but at the same time loose some top?? is this so?? im gona go bye the auto wrecker one day after work and pick up a set of heads to build up.. but not sure if i should go with 305 heads or 350 heads again... bye the way my motor is a 80-85 350 sbc.. and if i did go with the 305 heads.. wut would i look for.. a set off a 80-85 camaro? i no they had 305's.. thanx
i had a 79 sbc 350 with stock pistons...2102 edel. cam air gap and 600 cfm 4b carb. i used a set of 416 casting 305 heads...works great...but i lost a lil over 100 rpm for top end thats about it...the low end though it just burns the living hell out of my tires. hope this gives you some idea.
  #27 (permalink)
Old 06-03-2010, 09:04 AM
I understand all the drag racers are freaked out about loseing 100 rpm off the top end, but the rest of us whos cams stop making power way before that any way, I dont see the down side.
  #28 (permalink)
Old 06-08-2011, 01:50 AM
305 heads on a 350
Would a set a 305 head work on a 350 with flat top piston stock piston the 350 came with I was just wondering and can you run pumped gas the motor has a edelbrock manifold and 600 cfm and would I get more power
  #29 (permalink)
Old 06-08-2011, 06:31 AM
cool rockin daddy's Avatar
save yourself a lot of work and money and get a set of Vortec heads off a 5.7 truck engine and get a matching Vortec Manifold. Putting 305 heads on a 350 is a total waste of time unless you can port heads and can put a ton of work into them. Vortecs will give you the best intake port GM has come up with along with the modern heart or kidney shaped combustion chamber. If you have a boat, the 305 heads make great anchors.
  #30 (permalink)
Old 06-08-2011, 11:32 AM
Ya but I don't have money for vortec heads I got these for free the truck I would but them it is a 1968 Chevy c10
