Thread Tools Search this Thread share on Facebook
  #1
Old 03-19-2009, 02:50 PM
robbiesmechanic robbiesmechanic is offline
305 heads with 1.94 valves on a semi stock 350?
i bought this amazing 84 gmc pickup for $100. www.cardomain.com. it had a worn out 305 in it, and i am in the middle of an engine swap for a 350. i have bought 2 sets of 350 heads and neither one was what they were supposed to be. i have a set of 1.94 valve 305 heads. i was wondering if this would surffice until i had the money to buy a good set of 350 heads? the specs of the engine are: stock crank turned .10 on main and rod.., 495 lift comp cam with 295 duration intake/exhaust. new lifters and springs to match cam. new stock bore, 4 valve flat top summit pistons with new rings. and a built quadrajet 4 barrel. this is just for the street. will this work for time being?
Register now (free) or login to remove ads
Old 03-19-2009, 03:49 PM
oldbogie oldbogie is offline
Depending on what your using for a head gasket and how much the block's been decked, if any, this should pull about a 10.2 to 1 compression ratio. The cam has a lot of duration if this translates into mucho-grande overlap and a late closing intake, the dynamic compression should be around 8.6 or so. You should be able to get away with this from an iron head and 91 octane. Ported with big valves, you may discover that you don't need to replace the heads. Modified 305 heads on a 350 were always sort of a poor man's Vortec long before L31 Vortecs existed.
Bogie
Old 03-20-2009, 05:03 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Which "305 heads" do you have? casting number. They are not all created equal.
Some of the 305 heads have a very restricted exhaust port. "434" casting has this.
The 416's are the best 305 head to start with. Even these need a full port effort.
It can be done and done well if you are willing to do the work.
What cam is that specificly? It seems big for a pick up truck.
Old 03-20-2009, 10:48 AM
maxpower_454 maxpower_454 is offline
I didn't think there were any 305 heads made with 1.94 valves but maybe I'm wrong or they were done afterwards
Old 03-20-2009, 09:19 PM
Hippie's Avatar
Hippie Hippie is offline
Last journal entry: HEI comparison.
You "think" correctly......
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "305 heads with 1.94 valves on a semi stock 350?"
ThreadThread StarterForumRepliesLast Post
Stock 350 with 305 truck heads?CrazyTEngine308-04-2009 01:15 PM
305 heads on a 350 (not from the same year)SEEYALATEREngine409-28-2007 10:20 PM
How much power can I expect from stock 305 Vortec heads produce?Lil Big MecEngine303-07-2007 08:50 PM
305 head on 350savman1Engine410-15-2006 09:18 PM
305 heads on a 350?ZederEngine306-22-2003 07:11 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
