Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 heads
Thread: 305 heads
Old 11-10-2012, 09:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 71malibuproject View Post
Will 1980-86 305 heads fit on a 1971 307 ? Casting Number 14014416 . Upper (aluminum) timing gear stripped. Bent vavles but did not damage pistons. Thanks!!
They sure will. GM shoulda been whipped for those aluminum/plastic timing gears!
Be aware that all the shredded plastic from the cam gear ends up clogging the oil pick up, so if you can remove the pan and clean the pick up screen real good or just replace the oil pump and pick up w/a new one. You don't need a high volume pump for a mild build, the standard volume pump is fine.
