Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 heads
Thread: 305 heads
Old 11-10-2012, 12:05 PM
Hippie's Avatar
Hippie Hippie is offline
Last journal entry: HEI comparison.
What 'cobalt327' said.......
416's are excellent heads for a basically stock '71 307, if it still has the stock cam I'd slip a mild hydraulic cam like the Summit 1102 in it while you have it down to the shortblock. The '416 heads and an "RV" type cam really wake older 305's and 307's up without ruining them as daily drivers. There will never be a better time, all the hard part will already be done all you have to do beyond what you'll already have done is slide the old cam and lifters out and install the new then break in the cam for 20 minutes when you fire it back up. If you want a little bit of a lope go with the Summit 1103, it will still work with a stock converter and gears in a 307 but IMHO the 1102 makes a better driver, especially if it's a heavier vehicle like a pickup or Impala. Just sayin'........
The Following User Says Thank You to Hippie For This Useful Post:
cobalt327 (11-11-2012)
