305 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2012, 09:51 AM
305 heads
Will 1980-86 305 heads fit on a 1971 307 ? Casting Number 14014416 . Upper (aluminum) timing gear stripped. Bent vavles but did not damage pistons. Thanks!!
Old 11-10-2012, 09:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They sure will. GM shoulda been whipped for those aluminum/plastic timing gears!
Be aware that all the shredded plastic from the cam gear ends up clogging the oil pick up, so if you can remove the pan and clean the pick up screen real good or just replace the oil pump and pick up w/a new one. You don't need a high volume pump for a mild build, the standard volume pump is fine.
Old 11-10-2012, 11:05 AM
Hippie's Avatar
Last journal entry: HEI comparison.
What 'cobalt327' said.......
416's are excellent heads for a basically stock '71 307, if it still has the stock cam I'd slip a mild hydraulic cam like the Summit 1102 in it while you have it down to the shortblock. The '416 heads and an "RV" type cam really wake older 305's and 307's up without ruining them as daily drivers. There will never be a better time, all the hard part will already be done all you have to do beyond what you'll already have done is slide the old cam and lifters out and install the new then break in the cam for 20 minutes when you fire it back up. If you want a little bit of a lope go with the Summit 1103, it will still work with a stock converter and gears in a 307 but IMHO the 1102 makes a better driver, especially if it's a heavier vehicle like a pickup or Impala. Just sayin'........
The Following User Says Thank You to Hippie For This Useful Post:
cobalt327 (11-10-2012)
Old 11-10-2012, 11:22 AM
Thanks
You all are awesome!!!!!!
Old 11-10-2012, 01:29 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Please read through this tutorial and heed its cautions.....
http://www.crankshaftcoalition.com/w...ips_and_tricks
The Following User Says Thank You to techinspector1 For This Useful Post:
Hippie (11-10-2012)
Old 11-10-2012, 06:19 PM
Hippie's Avatar
Definitely!
305 heads or 350 heads on sbc 355 ryan v Engine 7 09-20-2012 10:21 AM
305 "416" heads on 305 .40 over...What would the comp ratio be? GMMAN Hotrodding Basics 7 03-24-2011 11:41 AM
350 heads or 305 heads...??? jkingof9561 Engine 13 05-12-2008 12:53 AM
283 w/305 heads. 305 head gasket? malibu65ss Engine 2 01-16-2003 02:07 PM
350 heads or 305 H.O. heads????? crshrmn3 Engine 3 08-25-2002 08:51 PM
