305 heads on 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 07:13 AM
305 heads on 350
how well will steel shim gaskets work with 305 heads on a 350
Old 02-26-2012, 08:18 AM
68NovaSS's Avatar
Wiki Edits: 9
They'll work fine if the block and heads are true/flat and valve lift isn't over the top. Keep in mind gasket thickness and piston deck height will effect your c.r. and squish.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
dart heads vs vortec heads repeat Engine 49 03-12-2012 03:56 AM
swapping 351W heads for 302 heads babell7738 Engine 10 01-21-2012 10:16 AM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
