305 heads or 350 heads on sbc 355 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2012, 07:17 PM
i'm looking into rebuilding the 355 in my 87 chevy truck. It currently has a set of 993 heads on but i got my hands on a set of 354434 heads off of a 305 that came out of a 77 chevy monza. The truck wont be used on the road its set up for a mud truck. i won't be doing anything to the heads other than putting heavier valve springs on so i can run a bigger cam. Which would be the best choice to use?
Old 06-10-2012, 10:35 PM
so i'd probly be better off stickin with the 993's and just runnin flat top pistons? i don't really wanna dump a bunch of money into 305 heads when i got a set of 186's that need redone. It sucks being broke. lol
Old 06-12-2012, 12:19 PM
What are a set of 186's worth i'm pretty sure they aren't cracked but they do need new valves? I'm not really wanting to get vortec heads because i'd have to get a new intake. I'm on a real tight budget so im trying to save as much money as possible.
Old 06-12-2012, 12:28 PM
i just bought a pair of 305 heads casting number 601 that had been ported, fitted with 202 160 stainless steel valves, new seals, and new 500 lift springs for 380 a pair
combustion chamber size is 58cc and i'm very pleased, a lot better than my 76cc smoggers
Old 09-19-2012, 11:26 PM
Proud LOSER
That's alot of valve for a tiny chamber no?
Old 09-20-2012, 11:21 AM
They're advertised at 58cc, the orginal casting for these heads call for like 55 cc chambers, after deshrouding them to actually make the bigger valves fit I'm sure the chambers are actually closer to 60ish ccs
Well they work fine, most 305 heads don't let you rev past 5k , and I easily rev my engine to 5500rpm, it seems to want to rev higher but I never take it above that
Sbc 350 w/ 305 heads.. kingofny1997 Engine 13 04-14-2013 09:11 PM
sbc 350 305 heads on propane bsfor Engine 4 01-25-2011 07:34 PM
SBC 305 Heads on a 350 ???? Brawler Engine 8 01-06-2009 10:48 PM
SBC 305 Heads on a 350 ???? Brawler Engine 0 07-15-2007 05:03 PM
350 sbc..305 heads?? learjet60 Engine 6 01-28-2005 09:28 PM
