305 heads on a 350 (not from the same year) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2007, 01:48 PM
i'm going to put a set of 305 heads on my 350. i have a set of the 305 heads off of a 85 chevy 305 and my 350 is a 91 model. will these heads work or do i need heads from something newer?
Old 09-28-2007, 02:08 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If the 350 is from a truck you can't use the truck's intake on the 305 heads. Starting in 87 on the trucks the center bolt holes are a different angle.
Old 09-28-2007, 04:46 PM
thanks
ya i knew that there had to be a difference. thanks for the info.
Old 09-28-2007, 05:24 PM
curtis73's Avatar
Wiki Edits: 16
The heads themselves will interchange, though. Is there a specific reason for the 305 heads? They might skyrocket compression and cut flow a lot.
Old 09-28-2007, 11:20 PM
E.T. divided by $ spent= Speed
305 heads on a 350 is a cool trick for a lowend motor. I had them on my last 350 with a mild cam in it.Would not rev past 5000rpm for anyone but it had some seriopus lowend and throttle response.
305 vortec heads vs 350 vortec rimracers Engine 6 04-02-2007 09:41 PM
putting 305 heads on 350 low77ride Engine 8 01-08-2004 04:43 PM
350 Heads on 305? JohnyR17 Engine 6 01-05-2004 09:53 PM
305 heads on a 350 stfinney Engine 10 05-07-2003 09:29 PM
305 heads on a 350...take a look.. TheZaZ Engine 2 07-15-2002 03:13 PM
