Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 heads for my 307 small block chevy
Old 12-23-2010, 07:57 AM
ap72 ap72 is offline
Banned
That cam would be a good match, but it'll require the correct valve springs and good oil, if you get the kit with the springs you'll just need to watch your oil, and be sure to check the installed pressure.
As far as heads... in Chile you may need to deal with what you can find. At that lift level good bowl/valve seat/chamber work will make the most difference.
