#1
305 ho
anyone know about 305 ho tpi engine camshaft specs
i have 2 engines a 85 ho 305 and a 88 350 from a truck i am doing a low budget thing and was wondering if the cam would be a good swap into the 350 for a little extra pep? Register now (free) or login to remove ads |
#2
You can find the 305TPI cam specs on the thirdgen.org site. It's not cost effective or wise to try to use a used flat tappet cam in a different motor. You can buy very good budget high perf cam+lifter sets from summit for $80. eg: simmit cam set #K1102 K1103 etc etc. The cams that come in the newer GM 350 crate motors eg: 350/355hp ZZ4 are very good if you want a affordable Hyd roller cam. You can often find this cam for sale on ebay. Last edited by F-BIRD'88 : 02-06-2009 at 10:04 PM. |
| Thread Tools | Search this Thread |
| Similar Threads for: "305 ho" | ||||
| HO 305 Heads? | Mike_82 | Engine | 8 | 01-26-2005 08:23 PM |
| Cam for '85 HO 305? | Mike_82 | Engine | 11 | 11-22-2004 08:06 PM |
| 305 ho engine build up, what do you think? | 406 ss monte | Engine | 7 | 11-21-2004 12:28 PM |
| 1986 chevy 305 HO roller? | 87442lover | Engine | 6 | 06-07-2004 09:42 AM |
| Will chevy 305 HO heads fit on a 350? | sugarmonkey | Engine | 5 | 01-16-2004 07:07 AM |
