Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 ho cam
Thread: 305 ho cam
  #22 (permalink)
Old 12-19-2012, 10:38 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Originally Posted by buggy305 View Post
will i be alot better off with the 1.94 valves and porting with a farly mild cam as opposed to porting the stock 1.84 ? ive been doing lots of reading on porting the last couple days and i think im going to give it a try there really only is one way to learn
Yup, now you are getting the picture. Find a old junk SBC head to practice a bit.
Porting with the stock 1.84" valve will improve flow for sure but porting + the larger 1.94" valve (with a new valve job) will make more flow, cause the valve is just bigger.
The 1.94x 1.60 valve combo is for a ported 305 head on a 350 motor.
The modded (cam etc) 305's power band is going to be much higher rpm than the stock motor.
It wants to rev. (Gears, converter) with 35" tires you will need some serious gears. It will be lame with the wrong gears.
A hot rodded 305 SBC becomes just as much as a high rever as a 302SBC is famous for. wants serious gears to perform/
The long stroke has nothing to do with it.
If your headers are "zoomies" convert/modify to a long tube style with collectors. ( more power/more torque)
