Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 ho cam
Thread: 305 ho cam
  #29 (permalink)
Old 12-19-2012, 11:20 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Originally Posted by buggy305 View Post
sorry didnt see your last post thank you
ya the RPM manifold is flat out a much better intake manifold.
worth the upgrade. The holley 300-36 is another good one.
Once the cylinder heads are nicely ported the motor likes extra valve lift.
So if you happen to trip over a set of 1.6 ratio SBC rockers, they will help.
.484" net lift with your cam. (don;t loose sleep over this)
(The push rod slot in the head needs to be extended a bit towards the rocker stud)
