305 ho cam - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-19-2012, 11:57 AM
F-BIRD'88's Avatar
Yada Yada Yada
The amount of actual chamber de shrouding is very very small. and its not where you think it is.
A very minimum of metal removal is all that is nessessary in the chamber to fit the larger valve.
These heads can be flat milled to a finished 51cc when all done. The physical limit is the spark plug boss and edge of the 1.94" intake valve seat.
CC the heads after rework/before milling for compression.
they will end up around 62cc when all done. CC and mill as required.
use a thin .015" felpro 1094 head gasket
Does this 305 have a flat top w 4 valve relief piston (L-69 motor) or a dish piston in it?
ya it matters. that 218deg cam needs compression.
you do not need to get all carried away with deshrouding on this head.
Use a drill bit to "gauge" the chamber wall to stock valve edge clearance, when the valve is partally open. Compare the to the larger new valve.
(.050" bigger valve radius) don;t get carried away. This is not a hi flow area. most of the flow is directed towards the spark plug in the chamber, on a SBC head. On this motor you need the compression ratio more than the chamber flow improvment.
Do not get carried away deshrouding.
Thats the whole point of just going to a 1.94" valve on this head.
flow your garden hose thru the intake port to see the flow pattern.
  #32 (permalink)
Old 12-19-2012, 12:06 PM
F-BIRD'88's Avatar
Yada Yada Yada
Unless you got and will run a 25" tall tire the 4.11's are useless on this combo.
35" tires need a 5.13 gear minimum ( not less than)
a 5.57:1 ratio is just right for this combo with 35" tall tires.
the hot rodded 305 needs to rev to make its power.
  #33 (permalink)
Old 12-19-2012, 02:54 PM
vinniekq2's Avatar
35 tall tires/4.11 gears/turbo 350 transmission/2800 pound car/6500 rpm
first gear=66//second gear=109//third gear=165
5.13 gears
first gear=52 ///second gear=87///third gear=132
If you do not want to register, fill this field only and the name will be used as user name for your post.
what cam for 305 crashu1972 Engine 10 09-05-2010 04:27 PM
cam for 305 ho Imaginos Engine 5 03-31-2010 10:51 PM
305 cam V305 Engine 4 05-11-2007 09:46 PM
305 cam handyman Engine 2 09-07-2004 12:22 AM
305 Cam Silver_Camaro Engine 17 11-02-2003 06:27 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
