305 HO mods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2003, 07:21 PM
New Member
Post 305 HO mods?
Ok no use swapping cranks. By using a 305ho is there any way to get just a bit more out of it? Maybe swap out for a 327 cam - or run bigger jets on the fuel injectors? Maybe go a bit bigger on the valves and stick some headers on? I know 305's aren't much to brag on but there must be some way to do the HO version justice?
Junior - the advice is much appreciated - am a newcomer to building power motors. <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 01-22-2003, 08:02 PM
E.T. divided by $ spent= Speed
Post
Depending on what ya wanna spend there are aftermarket heads availible for 305s I think World makes the "305 torquers" I think there called.
Also a mild cam that matches your drivetrain and engine mods.
Aluminum dual plane intake and Carb.
Small tube headers and duel exhuast.
I could see 325Hp 340lb/ft of torque with these mods.
