305 HO roller rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 02:31 AM
cam specs for L69: 202/206, .403/.415, 114.5
could i use 1.6's on it?
Old 02-23-2012, 12:38 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What heads, springs and pistons?
Semper Fi
Old 02-24-2012, 08:42 AM
casting: 601
58cc chambers (60cc ?), 178cc runners (158cc ?)
valve size in L69 heads were larger
L69 : 1.84/1.50
L69 has 9.5:1 CR (flat tops)
Old 02-24-2012, 08:45 AM
The original springs had 100 pounds of seat pressure, but only had a rate of about 200 lbs/inch. This means that the spring pressure at full lift would be about 200 pounds.
Old 02-24-2012, 08:50 AM
they should hold up to .450
Old 02-25-2012, 08:17 AM
..........Bump
Old 02-25-2012, 05:27 PM
1971BB427's Avatar
When changing ratios you'll need to check for correct pushrod length. The new 1.6 ration rockers will be slightly longer and may not roll across the center of the valve stem, which could create an issue where it wears incorrectly, or even comes off.
You'll need to mock up the heads, cam, rockers, and a pushrod, then check by turning the engine over with the rocker adjusted to zero lash, and see if it rolls on the valve stem close to center, or off to one side. If it's not centered then either longer or shorter pushrods will be required to get the pattern centered.
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 04:12 PM
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 11:15 AM
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 01:52 AM
roller rockers and cam VS. standard cam and rockers slipfreak84 Engine 5 09-30-2008 11:55 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 01:18 PM
