Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-31-2008, 01:58 PM
malibus~most~wanted malibus~most~wanted is offline
305 intake bolts
so on my new but old 86 305 the intake has only the four corner bolts....there are no two bolts in the middle. im asuming somthign is wrong with this because i have oil that is covering the side of my carb. im not sure if the bolts broke off or what. i need to know if there shouyld even be bolts in those holes. thanx!
Old 03-31-2008, 03:26 PM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
re: 305 intake bolts
Is this a carb'd intake or TBI?
On the carb'd version, there are 6 bolts on each side of the intake. The 4 corner holes do NOT enter the oil area. The rest do! If you are missing bolts, you will have a mess on your hands, not to mention vacuum leakes.
Old 03-31-2008, 03:28 PM
RippinRon's Avatar
RippinRon RippinRon is offline
Most definitely! If not those holes go right in the the lifter valley which would be where the oil is coming from. You should put some rtv on the threads for those bolts.
Old 03-31-2008, 05:22 PM
yea well on the driver side in the middle, the front one is broken off in the block and the one after that is missing, oil is coming out of that. on the passenger side in the middle the first one is missing and not so much oil is coming out of that one as the drive side is then the next one is broken off in the block. i just tried to screw new bolts into the block and i cant get them started. the intake hole isint really lined up with the block on the driver side. is there any way i can just stick some rtv in those holes for now untill i replace the intake with an after market one and just tap those ones out?
Old 03-31-2008, 05:31 PM
Jmark's Avatar
HR moderator dude
wow, that's a tough call. Personally, I'd be concerned with vacume leaks and leaning out and burning a piston. You really need to remove the intake and remove the broken bolts. They should come out easy since they are in an oily enviroment. Just don't try to drill them UNLESS you use reverse twist bits. If you can't get them out easily, get some help. You don't need metal shavings in the engine or broken drill bits ruining your chances of removing them safely.
Mark
Old 03-31-2008, 05:41 PM
well if i will be tryign to get a new intake in a few weeks what would you do for the time being? since its a dayly driver could i just stick some rtv in it and stop the vacum leak? and could it also blow out the intake gasket over time?
Old 03-31-2008, 05:53 PM
Jmark's Avatar
HR moderator dude
You could try to seal up the holes FOR A SHORT TERM fix. As far is it leaking vacuum, it may or may not. Is it running ok other wise? or missing at idle a lot?
Old 03-31-2008, 05:56 PM
the only think it is doing at idle is its going up and down very little. i dont know how many rpm's difference since i dont have a tack but it only sounds like maybe 500-800 rpms difference. sometimes it does it and sometimes it dont
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "305 intake bolts"
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Good intake for a 305 Ozz1967 Engine 3 05-31-2006 11:34 PM
What year did Chevy change the SBC intake bolts STATUTORY GRAPE Engine 5 01-04-2006 08:06 PM
Fabricating intake manifold. gemini86 Engine 20 05-13-2005 12:08 AM
Beware of Weiand Action Plus intake! 454C10 Engine 3 03-11-2005 07:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
