305 mess - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2012, 09:39 PM
305 mess
i have a 305 that a guy built for a street stock and the only thing i did to it was put new valve seats and springs and retainers on it .it has a 460 lift solid lifter cam ,not sure about duration and ,im having trouble with popping out carb around 3000 rpms, i had the valve covers off and checked rockers ,i adjusted intake to .018 and the exhaust at .020 and still have popping ,sounds like she is running on about 6 cyls just before it gets to 300 she wants to go,and then it breaks down .it has a new holley 600 on it and was running great. i got a 305 harmonic balancer for it and when i tried to time it ,the marks are no where even close.any help would be nice ,ty ,bud
Old 12-12-2012, 09:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Check the firing order. Pat particular attention to the wires for #5 and #7- they're next to each other at the cap and at the spark plugs so it's very easy to swap the wires.
There are three commonly encountered timing tab/damper line combos. If the parts are mixed up the timing as seen w/a timing light will be wrong. More here.
Was the cam broken in correctly?
If you have a HEI distributor, it needs a full 12 V-plus to the coil. No ballast resistor or resistor wire like the factory used on points ignitions. What about the ignition advance?
Vacuum leak? Fuel filter? Fuel pressure? Fuel old or stale?
Old 12-12-2012, 10:32 PM
you might find this a bit weird ,i bought this motor after it won 4 championship races ,she has some milage on her,he ran a 500 holley 2 bbl.anyways this engine is in a 73 chevy half ton step side with 6 inch lift and 35 in all terrains on it ,might be too much for this truck,im also thinking that the torque converter might be the issue.it has a b&m stall speed 2200 to 2400 hole shot the truck is idleing at 900 rpms and when i shift it it feels like the tranny is gonna come out of it or a universal is gonna drop out and the rpms drop 2 between 200 and 400 rpms all but dies.if i turn idle down it will not run in gear
Old 12-12-2012, 10:36 PM
the wires ive gone over a dozen times ,the 5 and 7 are confusing to me and could see me putting them on wrong ,but they r ok
Old 12-12-2012, 10:46 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
The Idle issue may be timing and vacuum advance! If you are even running vacuum advance? At 900 rpm the vacuum to the advance canister is advancing the timing and when put in gear the idle drops, vacuum drops off, and it retards the timing and the engine wants to stall ! unplug the vacuum line at the dist. and plug it off and then set the timing and Idle ! when you have it idling good try putting it in gear with the vacuum line still plugged and see if it still try's to stall.
Jester
Old 12-12-2012, 10:50 PM
ty jester and cobalt ,i have some things to check out ,thanks again and i will let you know if i find anything
Old 12-12-2012, 10:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If there's not enough initial timing, the carb primary butterflies have to be opened so far the carb is now trying to idle on the transition circuit between the idle and main circuits. It does not like to do that and the result is a poor idle that will almost cause the engine to stall when going from Park/Neutral to Drive.
One way to tell if this is happening is if the idle mixture screws do not have much or any effect on the idle.
Old 12-12-2012, 11:11 PM
What Cobalt says is true theirs another cause for no change when the mixture screws are screwed in all the way and the engine doesn't stall at idle, I would like to add and that's a blown power valve. That's at Idle! not at 900 rpm into the transition or main circuits.
Jester
Old 12-12-2012, 11:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You meant seals, not seats, right?
These new springs- do they have enough installed height? Not coil binding? Check the valve lash hot to be sure the valves aren't too tight or even being held off the seat once warmed up.
Old 12-12-2012, 11:25 PM
vinniekq2's Avatar
check for broken springs too.
Old 12-13-2012, 08:28 AM
305 mess
I would start from scratch. Use a piston stop in the #1 spark plug hole to find TDC. Remove all the spark plugs. Rotate the crank past TDC to install the piston stop. Continue to rotate the crank with a breaker bar and socket on the damper bolt clockwise until you feel it gently touch the piston stop. Make a mark on the balancer and rotate the crank counter-clockwise until you feel it gently touch the piston stop again. Mark the balancer again. Split the difference between the lines and you have TDC. I hope TDC is on the original balancer line. The 305 engines timing cover scale is at the 12:00 position. If the scale is at the 2:00 position it has a 350 timing chain cover installed. Check the casting numbers on the block behind the alternator to make sure it is a 305 engine. Once you have found TDC pull the drivers side valve cover and turn the crank 2 revolutions watching #1 exhaust and intake valves. When both valves have opened and closed the balancer line should be back at TDC. Pop the distributor cap to see if the rotor is pointing to #1 spark plug wire.
Old 12-13-2012, 02:45 PM
thanks for the input on the harmonic balancer , i will definately try that.the timing cover has the tube like thing for timing at 12:00 but it also has a dial on right side 2:00 and none hit at all,so ty i appreciate the tip.i will do that im a back yard mechanic and i mean back yard its cold out there .i did adjust the air on metering blocks ,i turned them out another 1/4 each and the engin picked up and smoothened out .im about to road test and see what happens. i also pulled the vac adv from dist and plugged it and then shifted it and same thing ,hard shift,could this converter be locked up? it is 7 yrs old
Old 12-13-2012, 02:49 PM
i also didnt find any broken or binding springs the guy that built the motor told me what to get for springs for that cam and thats what i got ,i dont remember what they were now but they seem fine
Old 12-13-2012, 03:02 PM
Sounds like you're having a detonation issue.....it is quite possible that this engine has a very high compression ratio & if you're running low octane gas it will cause it blow back thru the carb. Unfortunately, there is no easy way for you to figure out the compression ratio w/o breaking the engine down or asking the person you purchased it from
One other common issue w/ 305's is when the 305 HO heads are used w/ flat top pistons & big cams they tend to top out around 3000 rpms.
Old 12-13-2012, 04:27 PM
What intake are you running and where is you pcv routed to?
Jester
Yet another mess st3gamefarm General Rodding Tech 5 05-12-2012 05:04 PM
did i mess up?? 2112jb Engine 32 03-15-2007 10:50 AM
Uh what a mess!!!! Jag Daddy Electrical 1 04-11-2004 02:25 PM
Please help. Did I mess up??!! 1967stang Transmission - Rearend 3 01-05-2004 09:47 PM
no mess liquid_larry Engine 2 12-05-2001 07:41 PM
