305 needs more HP - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2002, 10:31 PM
Post 305 needs more HP
is there any simple things I can do to a stock 305 to boost hp. we thought about making a cold air intake for it but we are not sure how to fabricate it........
Old 12-29-2002, 04:38 AM
Post
How many miles on the motor? We had a camino 305 and they were infamous for bad cams. Get the heads done, different intake, cam, headers and you'll see an improvement. 305's weren't really performance motors, from the little I know about them, what about dropping in a 350?? You can get crate motors cheap, maybe an idea.
Old 12-29-2002, 04:55 AM
New Member
Smile
Lift off the air breather, install 350, replace breather. Just joking with you, but it would be the best step twords having power.
Old 12-29-2002, 06:37 AM
Post
This may give you a few ideas....
members.optushome.com.au/iroc-z/mods/320hp305/325hp305.htm
www.goingfaster.com/spo/343hp305.html
<a href="http://www.hioutput.com/tech/400hp/400hp.html]http://www.hioutput.com/tech/400hp/400hp.html[/URL]
Bottle feed it for the biggest increase.......Dan
Old 12-29-2002, 09:02 AM
Rubberman2003's Avatar
Post
Well if you like me and have no money (17, 18 on new years eve w00t) Get a Jegs catalog and take a look at some of there headers. I put a set of 350$ on my car, i got a lot more power(more than what it hough i would get) If your are REALLY broke if i remember right they have some cheap ones for like 100$ Just my 2cents
Old 12-29-2002, 03:47 PM
Post
The 305 is in my 83 el camino ss it only has 55,682 miles on it. We were thinking about dropping a 327 ci 375 hp motor in it but they are hard to find aroud here, so I figured just to try to find some performance parts for it.
Old 12-29-2002, 05:01 PM
Post
I know this may sound stupid, but ebay motors, engine section, there are a few engine builders offering warranties on their engines. they range around $2,500 - $4,000 for 380-480hp motors. You really couldn't build one that cheap much less get a warranty. I have never bought, nor do I know anyone who has, but I thought of looking into it myself for the next project.
Old 12-29-2002, 07:26 PM
Post
world products sells a 305 head. get the optional bowl blend from them or a local machine shop put in an extreme energy cam from comp a decent intake and carb to match the cam and a sniper NOS kit with a 75hp shot (it is safe on stock pistons) and presto Quick 305.
Old 12-30-2002, 01:40 PM
New Member
Post
start with a new cam and lifters- (decide on a cam
fist then look into changing other parts to
bring out the power.
my personal sugestion is a comp cams h270 or the next size down (magnum series)
with this cam (270) you want headers and flowmasters to start with then look into
intake and carb swap (performer rpm and
holly 650 dbl pumper).
the 270 cam can be run without a higher stall
converter. but lower gearing is a good help.
good luck
Old 12-30-2002, 02:49 PM
New Member
Post
I have a 305 in my 85 olds cutlass its power is not bad but the first thing I'd do if you can avoid the smog police is cut off that big cataltic converter off did wonders for mine. Just a thought.
Old 12-31-2002, 07:15 PM
Chucks,57's Avatar
Post
For all the work youl do go with a 350. go to the junkyard and try to find a 350 in a pick up 3/4 ton if you can they are all ways a 4,bolt be couse of torque and start there.
