Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 Quadrajet Rough Idle
Old 02-04-2011, 04:06 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Take some carb cleaner and spray around the base of the carb and anywhere around it that it could have a vacuum leak, And see if the idle changes when spraying these places. if it changes you have found a problem spot.JMO
It should smooth out if you hit a leak with the spray.
Cole
