305 sbc good idle, Dies when in gear - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-06-2007, 05:49 AM
Knows everything about nothing
Last journal entry: Ever forward
Originally Posted by 1970Chevy
I think its probably the intake manifold gasket that is leaking.
I recently took the manifold off and put it back on without replacing the gaskets. Now I can do it right (shouldve done it the first time ).
Don't feel bad. I still have a front seal that needs "fixing". When I changed the cam, I got in a hurry and didn't feel like taking the time to loosen the oil pan to get the gasket on the bottom of the timing cover in place. So... I just pounded the timing cover on with a rubber mallet and smeard silicone all over down there.
  #32 (permalink)
Old 11-06-2007, 07:38 PM
Last journal entry: epoxy paint
what does the magnetic stand do for the dial indicator or measurement? would I be able to measure what I need to with just a dial indicator ?
If it is a manifold leak (and im almost positive it must be) then how would changine the gears decrease the vacuum as significantly as it does. I understand how a vacuum leak would cause the symptoms the engine has, but why does the gear change double the trouble?
  #33 (permalink)
Old 11-06-2007, 09:10 PM
The magnetic stand just lets you put the dial indicator anywhere, except on an aluminum engine.
What gears are we talking about changing. If the timing gears or off the cam can be retarded or advanced from where it should be, this would affect engine vacuum. Changing rear end gears would have no effect on idle vacuum but will change cruise vacuum because the amount of throttle open is changed for the mechanical advantage of the gears.
Bogie
  #34 (permalink)
Old 11-06-2007, 11:14 PM
Sorry about the confusing post. Im wondering why the vacuum is so greatly affected by shifting into gear. At park the engine idles with 17 Hg" of vacuum. The moment I shift into reverse or first gear, the vacuum drops to 10 Hg". Im just wondering what is happening inside the engine that causes this significant amount of drop in Vacuum?
-Matthew
  #35 (permalink)
Old 11-07-2007, 05:37 AM
Because the carb might be too big thusly when the rpm drops the airspeed cannot keep it's velocity due to the carb size??? Just a very random idea. I really couldn't tell ya.
But now that I'm on that subject, I don't recall what carb you said you had but could it be possible your secondaries arent closing all the way?
It's probably best you ignore my random train of thought
  #36 (permalink)
Old 11-07-2007, 04:16 PM
main reason vacuum drops is because rpm drops. the engine is not pumping as much air at a lower rpm and therefore is not pulling as much vacuum against the butterflies of the carb. just like when you are cruising on the highway, higher load at a lower rpm vacuum will be higher, something like 20 to 25 or even higher depending on the engine size and whatnot, because of rpm and lack of opening in throttle blades. hope this blurb is correct and helps.
  #37 (permalink)
Old 11-07-2007, 10:47 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I think, in your particular case ... with leaking intake gaskets ... that it has to do with engine load.
If the engine is not under any load, (not in gear) it would maintain enough port velocity to deliver a lean fuel mixture ... but still enough to make each cylinder "carry it's weight", at least partially. The momentum developed by the "good" cylinders would also help to carry the ones not making a full contribution.
Once you drop it in gear ... the load increases, the port velocity decreases, and the momentum effect is largely absorbed by the torque convertor. Those cylinders that are not carrying their own weight are much more of a liability now ... and idle quality suffers.
Similarly, if you have a header gasket leak ... you don't notice it nearly as much until after you drop it into gear and put a little load on.
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
comet won't idle in gear comet boy Engine 3 05-06-2005 04:09 PM
late 70's vette dies in gear BuickLeSabre1960 Engine 4 09-29-2004 07:54 AM
Proper Jetting for Tri Power 305 SBC Not A T 25 Engine 0 09-21-2003 10:25 PM
Idle mixture screws only turned out 3/4. Runs good. BrackneyC Engine 1 04-28-2003 04:58 AM
