Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 sbc good idle, Dies when in gear
  #34 (permalink)
Old 11-06-2007, 05:32 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
While you have the intake manifold off, beg borrow or steal a dial indicator+magnetic stand and measure the cam lift at the lifter.. If you tell me the lobe lift of 1 intake and 1 exhaust lobe I can tell you with good accuracy what cam is in it.
If you r+r'ed the intake without replacing the gaskets its very likely you have a manifold vacuum leak. That would explain 90% of your tuning troubles.
