Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 sbc good idle, Dies when in gear
  #35 (permalink)
Old 11-06-2007, 06:38 PM
1970Chevy 1970Chevy is offline
Last journal entry: epoxy paint
what does the magnetic stand do for the dial indicator or measurement? would I be able to measure what I need to with just a dial indicator ?
If it is a manifold leak (and im almost positive it must be) then how would changine the gears decrease the vacuum as significantly as it does. I understand how a vacuum leak would cause the symptoms the engine has, but why does the gear change double the trouble?
