305 sbc with low oil pressure??? Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2002, 01:52 PM
New Member
Post 305 sbc with low oil pressure??? Help
Hey everyone, this is my first time posting anything on this site! It seems I am in a little bit of a problem. My '91 Oldsmobile Custom Cruiser has over 176000 miles on it and still rund fairly good. However, whenever the car has warmed up, and I am not moving (Stop light), my oil pressure will drop to zero and the needle on the gauge will be kinda wiggling and the light will be flickering. Kinda like i'm getting some pressure, but not enough. Once I put on the gas, the oil pressure goes back to "normal", but will drop again the next time it is stopped. What the heck is going on with my car?
Thanks, Carmen
Old 10-11-2002, 02:18 PM
New Member
Post
you kinda might want to stop driving her any more than you have to.do you have a gauge and a light? check to see if you got a leak where your switch or gauges hook into the block sometimes it will leak around there and will cause that.if that aint it your oil pump/bottom end are shot. was the engine ever rebuilt? somebody might have not put the oil pump pickup in right or they didnt tork the oil pump down right.(60ft.lbs.) i hope its the a leak where i talked about.
Old 10-11-2002, 03:49 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Cool
Welcome to the board.
Unfortunatly it sounds like your oil pump is about to give up the ghost! at 176000 mi. it's probably a tired motor did you change the oil? try going to a thicker oil, try a 20/50 see if that makes a difference. is there a lot of sludge in the oil return holes? theese are a few basic things to check. its really not to exspensive to change the pump you have to drop the oil pan.
i hope this helps you good luck.
Old 10-11-2002, 06:12 PM
E.T. divided by $ spent= Speed
Post
I had a pickup fall outr of the pump once.Replacing an oil pump in the car is a pain in the ***.Personally I would keep the oil changed often put a bottle of Lucus oil in and start looking for a low milage motor to replace it with.
Old 10-11-2002, 07:37 PM
New Member
Post
Hey guys, thanks for the help. I will look into what you said! I know the car has a lot of miles, but I love it! I would love to find a low mileage replacement for the motor, but unfortunately, I am only 17 and don't have that kind of money. I'd love to get a motor and rip it apart and rebuild it, but that's just kind of a dream. I'll check what you guys said and let you know what happens.
Thanks, Carmen
Old 10-11-2002, 07:40 PM
New Member
Post
Oh, and another thing, It's been doing this for way more than a year and the car still runs pretty good. It went through many oil changes since this started and it was never fixed. I put an additive in the oil that kinda makes it thicker, but it still drops pressure when its at idle (warm).
Old 10-11-2002, 08:04 PM
Post
Maybe try droppin the pan and change the oil pump.Its a pain but if you really like the car and don't have the bucks for a motor.ou can get a Small Block chevy for like $350,$200 for 305 if you look.
Old 10-11-2002, 08:20 PM
New Member
Post
A $200 engine? It sounds like that wouldn't be much better than what I have. Although, I could do some stuff to it before I put it in! I like the sound of that. (My goal is 300+ hp. Pretty unrealistic, huh?
Old 10-11-2002, 08:28 PM
Post
300HP just get a stock 350 pop in a decent cam,dual plane intake,600Holley,headers.
As far as a $200 motor I'm not talkin shiny new virgin motor with 5yr warrenty.I'm talkin a higher milage stock motor that has better oil pressure than yours and will get you to work reliably with out a smokescreen.If you look hard enough you can find good strong 350s for under $500.
Your car is that a Cutlass model???Is it rear wheel???I'm not familiar with that model.Just wonderin.
Old 10-11-2002, 08:32 PM
New Member
Post
Yeah, 300hp would be great! It's actually a B-Body (Caprice/Impala). My car looks exactly like a 91-96 Caprice/Roadmaster wagon, that's why I love it. A lot of potential with looks and performance. Right now, i'm just trying to get it to run correctly, then i'll mod. It definately rear wheel. It's stock 170hp and is probably down to 150 or less by now.
Old 10-12-2002, 02:15 AM
aka Duke of URL
Arrow
An -excerpt- from a Tech Article at Mellings.
[quote]When the pressure drops, we get our first signal that something is wrong in the engine. With the increased clearances/decreased resistance, the flow from the oil pump is at its maximum. This is like opening all the faucets in your house. Pressure is down, but flow is at a maximum. If we used a flow meter instead of a pressure gauge, we would see a gradual increase in flow as the bearing clearances increase with wear. But flow meters are more expensive and more bulky than oil pressure switches, making this method impractical.
A few comments about the relief valve in an oil pump. The spring pressure behind the valve determines when it will open. If it is designed to open at 60-psi, it does not have an effect on anything below 60-psi, unless it sticks open. If it does stick open, the pressure is low at idle, but builds up to 60-psi at the point the valve opens.
If an engine has excessive clearances in anything but rod bearings, the oil pressure will be uniformly low throughout the rpm range. If the rod bearings have excessive clearances, the oil pressure will be low at idle and will get worse as the rpm increases. Rod bearings turn in a circle rather than on an axis, so they are subject to centrifugal force trying to pull the oil out of the bearing. The amount of loss will vary depending on the actual clearances in every bearing and lifter bore.
This gives you an idea of how much flow increases with a small increase in clearances, and how pressure can drop when we exceed the flow available from the pump.<hr></blockquote>
[ October 12, 2002: Message edited by: KULTULZ ]</p>
Old 10-12-2002, 06:00 PM
Marcel
Last journal entry: Choo-choo town
Post
KUTULZ is right on target. my exp. is with bad cam bearing. i don't know olds, but sbc oil pressure with be low at idle on an engine which i call over hauled and called rebulit, which they didn't change the cam bearing will have the same problem you're having. sounds like bad bearing. look for a chevy with a bad body which runs good at a low price and roll up your slieves and dig in. elcome to the world of auto repairs. LOL
Old 10-12-2002, 10:03 PM
4 Jaw Chuck's Avatar
Post
Kultulz's quote is right on the money, rebuild time! Your engine has had better days and a spun rod bearing is in your future if you push that motor too hard. She's worn out, drive it normally or you could run into serious problems.
They don't last forever.
Outlawed tunes from outlawed pipes
Old 10-13-2002, 05:10 PM
New Member
Post
well guys, it looks like i'm in the hunt for a new motor, or is mine worth rebuilding. If i'm going to either swap engines, or rebuild mine, I want the result to be 300hp to the rear wheels. You guys are probably wondering why I am willing to put so much into this car and the truth is, I can't answer that. I can't explain why I like it soo much, I just do. I think it's how big it is!
I dream more than my wallet can handle
Old 10-13-2002, 05:21 PM
Harlequin's Avatar
Post
We all have that problem <img src="graemlins/drool.gif" border="0" alt="[drool]" />
