305 small block chevy hp. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2005, 12:54 PM
stickshift's Avatar
Last journal entry: selling the 60 chevy
hey i just picked up a 305 c.i. small block chevy motor its a 1980 to 1985 motor with a factory 4 bbl and it is supposed to be high output. it may have come out of a trans am does anyone know about what the horsepower rating would be. i keep getting allot of different answers. thanks stick
Old 04-04-2005, 01:12 PM
johnsongrass1's Avatar
Race it, Don't rice it!
6 hp
lol
Old 04-04-2005, 01:24 PM
stickshift's Avatar
yeah thats about what i figgured thanks stick
Old 04-04-2005, 01:40 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
bout 160 or so
Old 04-04-2005, 01:48 PM
ONEBAD70SS's Avatar
New Member
If I remeber right the max HP output on a H.O. 305 is around 180.
Old 04-04-2005, 01:59 PM
Wiki Edits: 3
the late 80's ones out the the camaros were all the way up to 220 horse. Carbed, flat tappet cam motors with the old heads I would figure about 160. I had a two bbl motor from 77 that was 140 horse stock, so a bit up from that, although I doubt much improvement was to be found in the heads, which is where it would count, by 1980.
K
Old 04-04-2005, 06:59 PM
stickshift's Avatar
thanks killer...........
Old 04-04-2005, 07:05 PM
firestone's Avatar
http://teamrfc.gospelcom.net
This should give you an idea.
http://64.233.167.104/search?q=cache...amaro+hp&hl=en
Adam
Old 04-04-2005, 07:25 PM
stickshift's Avatar
thanks adam ok next question how much more hp do ya think an edelbrock high rise manifold, carter carb and headers will add.. thanks for everyones answers...stick
Old 04-04-2005, 08:08 PM
Max Keith's Avatar
what HP?
The only 305 4 bbl ratings I can find in my Chiltons for 80-83 are 150 HP@3800 and 240LbFt@2400. I looked under all the chevy cars.
Old 04-04-2005, 08:10 PM
stickshift's Avatar
thanks ..stick
Old 04-05-2005, 05:45 AM
kstagger's Avatar
L69 305HO engines were rated at 180hp in the monte carlo ss. Same engine (if I remember correctly) was later rated at 190 in the F-body.
Start with exhaust, headers, a nice dual plane intake - I'm also running a compucam 2040 in my L69 305. But I'm replacing the 305 with a 355...
Kevin
Old 04-05-2005, 09:04 AM
stickshift's Avatar
thanks kevin . yeah im putting on an edelbrock manifold a carter carb and headers. this is a starter motor for my 34 chevy pickup after its all built and i run it around a while i may change motors.
Old 04-05-2005, 01:59 PM
roy383ci's Avatar
do u have the block numbers
you can check it out here maybe it will help
i still have a 305 did every thing to make it faster
headers dual free flowing exhaust
mild cam speed pro 2000
edelbrock manifold +600cfm carb
heads mild to 10:0 comp
full ported heads gasket matched
pulleys
ram air with pro flow edelbrock air cleaner
electric fuel pump
accel coil
electric fan
i think this 305 Haze 200 hp
Old 04-05-2005, 03:44 PM
stickshift's Avatar
thanks roy
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Small Block Chevy ID? Kenny13z3 Engine 13 07-08-2005 01:04 PM
55 chevy 4 door small block swap? mile-hightoyz Engine 0 02-19-2004 03:26 PM
Traco Small Block Chevy ID? EricTopless68 Camaro Engine 0 02-17-2004 07:09 AM
Small block chevy id Chevyjon60 Engine 1 09-14-2003 05:35 PM
