305 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2009, 10:04 PM
305 timing
Hey all I have an 81 k10 suburban with a 305. I keep setting the timing and it keeps changing. I'm not sure what the problem is. it has an H.E.I. distributor. Someone told me that the vacuum advance may be sticking, but I'm not sure how to check. I unhooked the vacuum advance and still have the same problem. Any help would be greatly appreciated. Thank you
Old 07-22-2009, 10:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The mechanical advance mechanism will over time rust and wear, springs will break and pivot points wear out their plastic bushings (if so equipped- not all were).
Bottom line, you likely need to take it apart and clean it.
This requires the entire dist. to come apart, the advance plate rides on the main shaft and if it's sticky, it'll need to come apart for cleaning, too.
It's not a hard job, but there are a lot of small parts, and you do need to pay attention, make notes as you go along and take pictures if possible.
A decent description of taking an HEI apart is HERE.
Old 07-22-2009, 11:45 PM
Is the shear pin at the bottom of the distributor broken? If it is, the timing will slip when you start the engine because the gear will spin on the shaft instead of turning it.
Old 07-23-2009, 12:20 AM
The shear pin is good. I reaplaced it about a month ago. Thank you though.
Old 07-23-2009, 12:25 AM
Better recheck it. If you replaced it, i would guess that it was broke. If it broke once, it will probably break again. I had it happen to me twice. Coincidentally, it was one month after the first time it happened. Also, the new shear pin could be defective, or not as strong as the original one.
Old 07-23-2009, 12:35 AM
Thank you for your help. I'm going to check the spring in the advance. That may be the reason the timing wanders.
Old 07-23-2009, 12:41 AM
It didn't break before it had something stuck inside it. The timing doesn't go around it goes back and forth. It just doesn't stay constant. When I drive it the idle goes up and sticks. Then when I shut it off it back fires.
Old 07-23-2009, 12:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
While you have the cap off, one thing you can do, is to turn the rotor against the springs and see if it returns completely when you release it. It should, and the springs should hold the advance mechanism "closed" against the stops when at rest, it shouldn't want to stay "open"- which will be advanced.
But it sounds like you will be able to see what's going on. Good luck.
Timing Marks ??? Zeder Engine 10 06-18-2013 04:19 AM
What to set timing at? SBC 305 / CS274 hon_jr Engine 19 10-23-2007 05:06 PM
305 chevy timing raymond spaugh Engine 1 02-09-2007 04:06 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
305 timing shaine32210 Engine 3 02-21-2003 09:55 PM
